How to burn 800mb cd in nero 7.0/8.0 oem
How to burn 800mb cd in nero 7.0 oem/ 8.0 oem
    Problem Solver:
Select overburn option in (Nero version 6.6)
first select data disk, more, configure, goto expert features select over burn feature and change Disk capacity to 90 Minutes. Happy Burning
venu babu namineni, computers & consumables, Ongole, Andhra Pradesh, India
Posted on May 06, 2009
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
How can i make cd write protected content in my...
1. Put a blank CD or DVD into the device you wish to write with.
2. When you install Nero, it will create shortcuts to many different programs. You want to double-click on the icon labeled Nero Burning Rom to start the program.
3. When Nero starts, it may start in the New Compilation screen. If it does, click on the Cancel button.
4. At the top of the Nero window will be a drop down menu containing a list of devices that you can write to. Make sure the CD or DVD Recording device that you wish to write to is selected.
5. Then click on the Recorder menu and choose Burn Image.
6. This will open a windows called Open which will allow you to navigate to the image file you would like to write. Navigate to the image and click once on it to select it. Then press the Open button.
7. A Burn Compilation screen will now open. At this screen put a check marks next the check boxes labeled Write and Finalize CD (or Finalize DVD)
8. When the writing is complete there will be a message box from Nero stating it is finished. Simply click on the OK button.
9. If you are finished, click on the Done button and Nero will eject the newly created CD or DVD.
visit given link for screenshot.
http://www.samplex.org/wp-content/uploads/2007/09/nero4.JPG
Feb 10, 2011 | Ahead Software Nero 7 Essentials Suite...
How do i convert personally recorded nwf to wma sound files
Hi ,
Open Nero Burning Rom and see if Nero recognizes your personal files . If yes , drag and drop them to the left panel , select the recorder in witch you have loaded a blanc cd and clic on
" burn compilation " . Nero is set to burn to WAV by default .
If this does'nt work with Nero , you can try another soft , for instance Switch Sound File Converter from NCH and convert your files to Wav on the HDD . And yes , it's free .
Regards .
Jan 05, 2011 | Ahead Software Nero 7 Essentials Suite...
Get the serial number of nero 7
Uninstall that pay-to-use software.
Access http://WWW.MajorGeeks.com and select the "AShampoo Burning 6" software.
Download this _free_ CD/DVD-writing software, and install it.
May 29, 2010 | Ahead Software Nero 7 Essentials Suite...
Have Nero 7 essentials, all music files are not burning correctly, when they are played back from the burned cd, music files skip and music sounds distorted. When I burn the same music files from my lap...
Sounds like your Nero ASPI file is corrupt download a new version HERE
Replace you original DLL with the one above and restart Nero ROM this should solve your problem.
Jan 02, 2010 | Ahead Software Nero 7 Essentials Suite...
Dvd write error
uninstall nero and restart computer . then reinstall nero
May 13, 2009 | Ahead Software Nero 7 Essentials Suite...
My nero 7 is not working properly.Pl repair on line the net is open.
It show that tere is a erro file somwhere that will not let me open nero
Cant install nero oem suite coz i have vista sp1
download nero 8 or later
lower version are not supported in vista
link
http://rapidshare.com/files/138052607/Nero_8.3.6.0_Ultra_Edition.part1.rar
http://rapidshare.com/files/138052609/Nero_8.3.6.0_Ultra_Edition.part2.rar
download the 2 files extract using winrar, install and enjoy
Apr 05, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
