Question about Maytag Dryers
Maytag mdg6000 dryer won't heat. It runs find, just no heat, vent is cleaned out.
  • 490 Answers
Your next step will have to be remove the heating element and measure resistance across it and see if it is bad
make sure to unplug the dryer first
Posted on Apr 14, 2009
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Maytag dryer is taking forever to dry clothes, can even smell bad while running? how do i clean it besides the lint catcher?
Make sure the vent is not clogged. Its in the bottom of back side. Typically vented outside. Also, verify your heater elements are working by running dryer with door open to check for heat
Jul 27, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer runs fine but the gas comes on for about 1 minute then shuts off. It may cycle once or twice then stops. The vent is clear and I cleaned the filter assembly and the fan housing.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 15, 2010 | Maytag MDG6000 Dryer
Sometimes heats, sometimes not.Ignitor is
if it just takes a long time to heat u need to check or clean your venting if not it could be ur ignitor,, or also some coils also called gas valve solenoid coil kit comes with both item number 3479 at repairclinc.com those are generic frig coils but would work fine in ur unit those fixes are allot less inexpensive then tryin to replace the timer assy
Jan 28, 2010 | Maytag MDG6000 Dryer
No heat when dryer running - Maytag mdg6000
Check for a blown thermal fuse or a faulty heating element. These components can be tested for continuity using a multimeter. A lack of continuity indicates a bad component. The thermal fuse is about one inch long and is located in the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 03, 2009 | Maytag MDG6000 Dryer
Dryer takes forever to dry clothes
This is a classic example of a clogged vent tube. Everyone cleans the lint trap, but seldom checks the tube that connects the dryer's output to the outdoors.
The tube should be removed and replaced if it is the flexible plastic type. The flexible metal tube can be used if you can clean it easily enough. The best tube to use is the sheep metal type. It can be easily cleaned and is very durable. Be sure to pay particular attention to turns or right angles of the tube - nearly always at the rear of the dryer - before it is directed away. Make sure the entire length is clear including the cap at the outside end - be it in the wall or roof.
Of course, if the heat isn't as hot as it used to be, there could be another heat source (gas or electric - or even both) related issue too. I'm betting that the vent has never been inspected.
Apr 07, 2009 | Maytag MDG6000 Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
