Question about Sony RDR-GX300 DVD Recorder
Sometimes when I record on my RDR GX300 and take the disc out planning to add more later it acts like it has been finalized and I can't add another recording to the disc. Any help?
I no longer record on a disc unless I'm going to fill it up at the same time.
Posted on Apr 15, 2009
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Unit cant recoginze/ read a disk
Randy,
I had a dvd-r disc recorded from a Philips dvd recorder that had not yet been finalized when the Philips went bezerk and died. I replaced it with the Sony GX300 and just for an experiment, tried to finalize it in the Sony
It worked. Not to say that it has to work with only THIS combination of the 2 same dvd recorders or twisting the scenario around with the Sony doing the recording and the Philips doing the finalizing. I also have a Sony dvd/vcr recorder to compliment the GX300. I will have to record a disc on the GX300 and try to finalize it with the combo unit to see if it will do well as a back up.
Right now a disc that is not full yet (home movie from my kids birth) is reading "Disc Error" on the GX300. I may have to do it over or see if the combo unit will do the same finalizing as the GX300. It doesn't have the amount of features that the GX300 has but thats what you get with a combo unit vs. a stand alone recorder/player.
If you know someone with another recorder, try to finalize on it. If not , you could find someone on this sight that has a GX300 and mail the discs plus a smalll fee and have them mailed back. Or you could find a used one cheap at some store and return it if it doesn't finalize.
Good luck
Dave
azsnoopy1@cox.net
Dec 28, 2009 | Sony RDR-GX300 DVD Recorder
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Scheduled recording stopped
first clean it.since you had recorded and stop, try another disc.
May 08, 2009 | Sony RDR-GX300 DVD Recorder
DISC ERROR
it could be a region problem. most dvd players are locked on certain region areas..like America being Zone 1 and S.A being Zone 2. imported or diffirent format of dvd's usualy gives a disk error message. if you think it might be region try www.videohelp.com. they give hacks for region problems^^
Mar 30, 2009 | Sony RDR-GX300 DVD Recorder
Sony dvd rdr gx300 failure to delete discs
You can delete titles on a DVD+/-R, but it will not free up disc space. These are not "rewritable (RW)" disks.
To reuse discs, start with a DVD +/-RW. Be sure to format it "VR," not "Video."
http://esupport.sony.com/perl/model-documents.pl?mdl=RDRGX300
Oct 12, 2008 | Sony RDR-GX300 DVD Recorder
Dirty Disk Problem with DVD+R Disks on SONY RDR-GX300?
I have used my Sony GX300 for a couple of years and love it. I prefer +R blanks. The only occasional problem is the media brand. It will not record Fuji 16X, but will record Fuji 4X, which are rare nowadays. I have used TDK 16X with success, but this week bought TDK "lightscribe" blanks, and the GX300 would not record with them.
Sony should provide an upgrade download for the GX300 but does not. On the internet I have been unable to find a list of suitable brands for this DVD recorder, so I have to take risks when shopping. Fortunately, all blanks can be used for my computer so my money is not really wasted.
It's October, 2009 and in Toronto there has been a shortage of DVD blanks for months. I've been told there will be lots available in December.
Sep 03, 2008 | Sony RDR-GX300 DVD Recorder
Disc Error message
UNPLUG UNIT AND LEAVE OFF FOR 1 MINUTE. THEN PLUG BACK UP AND RESTART
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
