Question about Xerox Office Equipment & Supplies
Need to reset an account in the job templates, and
Need to reset an account in the job templates, for a Xerox 7132, and keep posting ''user and password requested by Internet Services''
  • 24 Answers
When you browse in via the IP address, the Centreware Internet Service (CWIS) will ask for your username and pass word for certain operations. On the 7132, the username is 11111 and the password is x-admin (all lowercase). If that does not work, it may be that you exceeded the login attempt limit and will have to power off the machine, wait 1 minute and then restart it. This process usually takes less than 3 minutes total.
Posted on Jul 16, 2009
  • bpolania Aug 04, 2011
    I'm having the same problen but the 11111 user is not working, is it possible that the formar administrator chaged it? if so, how can I get back to factory default?
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
As always you can find answers to your questions at www.xerox.com/support
Solutions for : Enter up to 64 Characters in the Shared Name Field Message is Displayed When Setting up a Network Scanning Template Using CentreWare Internet Services (CWIS)Related Fault Codes: 016-782 Solutions ranked by relevance Solution : Modify the User Login Name to a User that Only Exists on the SMB Server Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Hope it helps!
Jan 10, 2011 | Xerox WorkCentre M128 Copier
The Windows 7 mini drivers for the Xerox 7132 only provide a limited feature set. If I install the Windows 7 driver for the Xerox 7232, will it work with all features on the Xerox 7132?
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Jul 14, 2010 | Xerox WC7232 Printer
Error code 016 781
The 016-783 error message indicates that “Cause – Could not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the scans in had previously been deleted, so I had recreated the shared network folder. What I had neglected to do though was to recreate the sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup referenced in the job template I had no more error codes with that scanning job template.
Jul 01, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox WC 7132 printer error code 016-601 error and error type illegal access detection
  1. Click on the "Configuration" tab
  2. Choose the account mode to "User"
  3. Click on "Detailed User Settings"
  4. Change the password details as per instructions from your printer administrator
cFor more help visit cbrtechsolutions
Sep 04, 2009 | Xerox WC7232 Printer
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I need the diferences between docucolor 12 and xerox 7132? please
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
RE : Xerox WorkCentre M128 016-782
May 19, 2008 | Xerox WorkCentre M128 Copier
RE : Xerox Work Centre M128 016-782
266 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
