Question about Cuisinart DCC-1200 Coffee Maker
Only takes a quarter cup of water to fill
When i went to fill the coffee maker this morning, it only took about a quarter cut to fill, it must be plugged somewhere, don't know the solution
  • 8,596 Answers
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water - you will have to dump the existing water out first. Let the vinegar/water solution sit in the water reservoir for about 20 minutes, and then press the ON button to begin brewing as if it were regular coffee. You may have to repeat the procedure up to 3 times, but it should clear out the blockage.
Posted on Apr 15, 2009
Keurig exploded k cup & very slow to brew
The water tube needs cleaning and the lower holder also. You have a clogged system and it needs cleaning.
Feb 06, 2013 | Keurig B60 Coffee Maker
I haven't had my keurig for a year. This morning I brewed 2 cups with no issue. I went to make my third and the lights flashed momentarily and then the screen went blank. Now I can't get it to even come...
Sorry to read about you issue.
try and unplug the unit and try again..if the unit starts again i suggest you follow the procedure below. if not the unit is defective....
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig B60 Coffee Maker
We have an FTX41 12 cup mr coffee maker. Suddenly all the water we pour in comes out the bottom all over the counter. What do we do?
Ours (FTX41) did this, made a pot of coffee in the morning just fine then a few hours later we went to make another and the water just poured out the bottom. I took out the 6 screws (4 philips and 2 torx under the rubber feet). When I took off the bottom one of the hoses to the heating element had come off. I put it back on and everything worked fine. It took about 15 min. to fix and put back together. Poor design on the hose connection, no clamps of any kind.
Jun 28, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Feb 14, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Jan 27, 2009 | GE 106591 Coffee Maker
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Jan 06, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
131 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
