Bosch Integra® 500 SHX46A0 Dishwasher
Problem for Bosch Integra® 500 SHX46A0 Dishwasher
Bosch SHX46A (6 years old) Selected
By pse9 on Apr 14, 2009
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on. I opened door, turned off On/Off switch, then poured water into drain. Then turned On/Off switch on. DW began pumping water OUT of the DW. Also, it doesn't matter if the door is open or closed - if you turn the DW on, the pump will run. I suspect a problem with the electrical controls, or perhaps the door latch sensor.
Same Problem
May 25, 2009
-   My bosch will run the pump with door open. It will not fill. It wont do anything but pump with door open or closed.-   hawk8
Best Solution
posted on Apr 14, 2009
Very Helpful)
meyerjr
Rank: Guru
Rating: 91%, 228 votes
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch IntegraŽ 500 SHX46A0
Questions and Unsolved Problems for Bosch IntegraŽ 500 SHX46A0
Do you recommend Bosch IntegraŽ 500 SHX46A0 Dishwasher?
Answer
Answer
My Bosch Integra SHU 9956UC is not cleaning properly after 8 years of use. Checked spray arms for... (More)
Answer
The dishwasher runs but the top sprayer bar does not move. Water comes out but it stays in the same... (More)
Answer
My 5 year old dishwasher won't stop running. It doesn't go to the next cycle and pump out the soapy... (More)
Answer
6-7 yr old Bosch Integra Ltd dishwasher. Handle screws came loose. Unscrewed "star" type... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Van Nuys, CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
