Question about Zanussi ZWF1430W Front Load Washer
Hi 1437 w problem is when the on/off button is pressed, it is already set to cotton daily etc 1.40 in the display window. No joy trying to clear this message, and no matter what buttons are pressed, (start, reset, delay) the ERR message is then displayed and I can make no further progress. I guess I need to clear this programme, any ideas Please? Peter
  • 1 more comment
  • pbhm Apr 14, 2009
    Hi Did plug it out for about 15 minutes yday and still no joy will try again.
  • pbhm Apr 14, 2009
    Hi unplugged for 70 minutes, problem still persists, Peter
  • pbhm Apr 14, 2009
    an i do that or do I need a callout? P
    Brigadier General:
  • 3,614 Answers
try to unplug the unit for an hour to clear the error message & also to reset the system.
let me know
Posted on Apr 14, 2009
  • 1 more comment
  • micromaster
    micromaster Apr 14, 2009
    ok, just let me know...
    just be sure that you will unplug it directly from the electrical outlet.
  • micromaster
    this can only be a control panel problem, a possible bad contacts do this problem. you may need to check the control board need to be clean for any dirt causing the problem, or for any damaged on the board that needed to be replace.
    let me know
  • micromaster
    if you have no idea how to service, it is better for you to call for repair to avoid further damaged on the unit.. it very complicated to service such electrical components if you have no knowledge working with it.
My stereo keeps turning off when I listen to a station 101.5 in New Jersey
The only thing that can be is that you have set a timer "sleep" function for that station. I have looked at the manual and it states you can programme a sleep setting for a radio station.
The instructions are on page 12. But I have extracted them below:
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
Jan 06, 2016 | Sharp CD-DH950 5-Disc Compact Stereo...
I can't set the alarm on a Bush dabcr2004/a radio alarm clock
If anyone still has one of these, and is struggling to set the alarm, try this:
For setting the alarm
Press the menu button. Press right arrow button 5 times until you get 'clock' then press select.
You'll see 'set alarm,' press select button again to say yes.
You'll see a display with all the current settings: Alarm 1, the current alarm time and whether it's set for Daily or Once. Pressing the right arrow now advances the hours, the select button moves you on to the minutes, set these with the arrow buttons too.
Select button now moves you to 'Daily' or 'Once' - again you change this with the arrows. Select button moves you on to choose Radio or buzzer (again, you change this with the left/right arrows and press select for your choice).
All settings are done, you can power off now, or I think pressing menu took me out of settings mode and back to radio display.
Turning the alarm on or off:
Press menu, then right arrow 5 times for 'clock.'
Select this and you'll see 'set alarm' - press right arrow button once and you get 'Alarm On/Off.
Now every time you press select, the bell symbol toggles from visible to invisible, visible being 'on.'
You can now press menu to get out of the settings mode.
Jul 20, 2011 | Audio Players & Recorders
Can not sync my ipod to my itunes keeps saying unknown error 1437.. dont know what to do next
Hi smdente... Anyone having problems with the error "1437" I have been searching the internet high and low and have done so much and I believe I have finally found a way to fix it. "1437" is the error where your ipod just wont register as an ipod and when it finally does it will begin to restore but corrupt halfway through saying error 1437.
First of all I got this code which you save in Notebook as appleipod.bat
regsvr32 /s softpub.dll
regsvr32 /s wintrust.dll
regsvr32 /s dssenh.dll
regsvr32 /s rsaenh.dll
regsvr32 /s gpkcsp.dll
regsvr32 /s sccbase.dll
regsvr32 /s slbcsp.dll
regsvr32 /s mssip32.dll
regsvr32 /s cryptdlg.dll
regsvr32 /s initpki.dll
You save as that to your desktop exit out of it then double click on it. A black screen will come up, load, then disappears.
Reset your unplugged ipod by pressing the center and menu button, once the apple logo appears press the center and play/pause button until it does into disk mode. Once in disk mode plug it into your computer and wait for itunes to register it and restore! KABOOM! fixed.. well, at least for now. I dont know if this was just by chance but this last step with the resetting your ipod didnt work the first time for me so I continued my google quest and on another website there was one more step. To have you ipod off and fiddle with the "hold" button the the top left of the ipod while off and then start the steps. It could have just been by chance but it worked so do try. Free answer...Please take time to rate me
May 16, 2011 | Audio Players & Recorders
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error : Oxc 18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 30, 2010 | HP Photosmart 3210 Printer
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
How to delete picture from canon powershot s5is
Press the set button located above the menu button to erase a single picture. The set button is like an enter button on a PC
Apr 25, 2008 | Canon PowerShot S5 IS Digital Camera
Zanussi ZWF1430W Front Load Washer Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
