Question about RCA CC4352 Camcorder
RCA CPR 300 Camcorder 1988 model
Camcorder is locked in "fast" mode and don't know how to get it out.
3 Suggested Answers
SOURCE: RCA CPR 250 camcorder not recording
I fixed it my self !
I guess I should start a website and charge $
Posted on Apr 10, 2008
janice7685
SOURCE: RCA camcorder stuck in safeguard
rca stuck in safe mode , how to get it out.
Posted on Oct 13, 2012
Rca540 camcorder will not show tape in eye pc unit runs but no picture in view finder
Is there a eletrical board that controls the opening & closing of the lens in front of the camcorder?
Aug 29, 2012 | RCA Pro Edit Camcorder Model Cc540
CAMERA SHOWS THIS CARD CANNOT RECORD IN VIDEO MODE. HOW DO I FIX IT?
I see two possibilities. Fortunately they have the same solution.
What type and speed memory card are you trying to use? Is the card compatible with the camcorder? Since you didn't specify the model of your camcorder I can't tell you what type of card you need to use, but if the camcorder is designed to use SD cards and you're trying to use an SDHC card then it won't work.
The second possibility is that your card isn't fast enough to record video. There's a lot of data involved in a video clip, and not all memory cards are fast enough to handle it. The situation is much worse with HD video. Again, without knowing the model of your camera I can't tell you how fast a memory card you need.
Apr 20, 2012 | Panasonic Video Cameras
Apr 09, 2008 | Video Cameras
JVC safeguard
I MADE MINE WORK!!!! With the camera off, I pressed and held the "play" button while I powered it on into playback mode. It actually let me watch the tape. I switched it to "REC" mode and still got the error. So I switched it off, pushed and held the rec button while powering it on... IT WORKED. Now I can power it on and off with no more error messages (so far)! Let me know if this works for you too!
Mar 09, 2008 | RCA CC9370 Mini DV Digital Camcorder
No picture
CCD sensor might be faulty. To check see if you get immage in playback mode ( some old tapes you know were captured properly ) if playback is fine but no image in capture mode ( i.e. camera mode ) then CCD transducer is kaput ; camera must go in.
Sep 02, 2007 | RCA CC6272 VHS-C Analog Camcorder
Can't access all the menus...
Some RCA camcorders feature both Automatic and Manual recording modes. Some features on these camcorders are only available in Manual mode. Check to make sure the POWER switch is set to M, and not A, then try again. If you are unsure of the recording model features of your camcorder, refer to the owner's manual or the product catalog on the website. Look on the bottom of your camcorder to locate the model number.
Sep 06, 2005 | RCA CC-432 Camcorder
Should I use automatic or manual while recording?
Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shotâ„¢ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shotâ„¢ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
RCA CC4352 Camcorder Logo
402 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
