Question about Acer Aspire 5315 Notebook
Less available Hard Drive Space than advertised
I have an Acer Aspire 5315 that i have recently bought from PC World, the advertised available Hard Drive Space is 80GB but i only have 32.5GB available. I have all the latest service packs and recently restored to factory default settings and have no hard drive partitions. Any ideas on how i can increase the available space on my Hard Drive?
THanks
  • 1 more comment
  • monsieurgaze Apr 14, 2009
    Sutchman - The total size on My Computer is 32.5GB
    All sorted it, on Disk Management Console it said that 33GB were "Unallocated", i therefore extended my volume and now i have full space available. Thanks
  • Tom Sutch May 11, 2010
    What does the total size say if you open up My Computer? It should say around 77GB.
  • 24 Answers
Try to flash a newer bios to system:
http://support.acer-euro.com/drivers/notebook/as_5315.html
Also look at your hard drive - >
right click on "My computer" -> manage -> disk management. There you should see all info about your hard drive. Maybe it's splitted in two partitions
Posted on Apr 14, 2009
  • 489 Answers
Run Disk Cleanup. (Right-click on the drive and select Properties, then click on the Disk Cleanup button on the General tab.) It will scan for files that are no longer needed on your computer and it may take some time depending on the speed of your computer and the hard disk. The default selections are probably the best, but do NOT remove the HIbernation file (or you computer will no longer be able to enter hibernate mode). On the More Options tab, you can click on the Cleanup button in the System Restore and Shadow Copies section to remove all but the last restore point that was created on your computer. This will allow you to get the greatest amount of space back from these restore points that you will probably never have a need for. But only select this option if you are sure that your computer is operating normally as it is right now, because you will only have a single restore point left in case of an emergency. Once everything you want is selected, click on OK to delete all of the selected material.
    President:
  • 2,004 Answers
Go back to Pcworld and buy an external drive or you change your hard disk to an higher one.
Good luck. But don't buy anything lesser than 120GB
My Acer 5315 Data as only 3.01Gb free of 32.5 Gb do I need a New Hard Drive to get more Ram
More RAM will not help because your RAM is temporary memory. You can uninstall the software you dont use or backup your documents/pictures/music to an external source and delete them from your hard drive. Another option is to use the Disk Cleanup utility to rid your system of temporary files that are taking up space or get an external hard drive to backup your files to.
Jan 26, 2011 | Acer Aspire 5315 Notebook
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
I just bought a acer aspire 5315 from a yard sale and was told the hard drive was bad. i went and bought a wd scorpio blue 250gb sata hard drive. after installing it i put in my windows xp disk to format...
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Sep 27, 2010 | Acer Aspire 5315 Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I want to upgrade my hard drive.
If you have 50% or more disk space free then you may not need a larger hard disk at this time. If you have 512Mb of RAM, you can get better performance with 1Gb or better still 2Gb of RAM if your Acer can support more than 1Gb of RAM.
Jun 09, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 refuses to boot up
plz try by reinstalling the operating system, if you cant then plz check your hard drive
Jan 13, 2009 | Acer Aspire 5315 Notebook
C: Drive space issue
Hi Ginnydoll,
You need to used Hard Drive Partition which you can resize your available space by increasing drive C: capacity and decreasing available space in your drive d: capacity without deleting any files on it. And this is not a harmful to your hard drive all your important files are intact in each destination.
If my solutions sounds great please email me for further assistance. diazphi@gmail.com. because it is really hard to demonstrate on this page because there is no features to attached pictures for visual instructions.
best regards,
Philip
Oct 30, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5315 Notebook Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
