Question about Canon imageRUNNER 2200
Error code definition
My Image Runner 2200 has shut down, I have followed all instructions and am getting error code 'E000220-0001.
What does that mean? I can work on the machine myself if you will tell me what needs to be done.
Please answer quickly, we are at a stand still
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
This problem occurs from your scanner lamp. You have to change that scanner lamp.
Posted on Dec 03, 2012
  • 135 Answers
All I can offer is From Canon:
Problem :
The machine displays an error code of E220. The code only displays when copies are made off the glass. Originals copied using the Document Feeder do not cause the code to occur.
Solution :
Unplug the copier and remove the Copyboard glass. Move the scanner manually and check to see if the Scanner Home Position Sensor Flag is coming into contact with the Inverter Pcb, or any of the wiring. Contact with the flag may be causing a short during Scanner movement when copying from the glass.
Problem :
Error Code E220-0001 occurs after replacing the Lamp, Inverter PCB and the Reader Controller.
Solution :
Check and verify the 24V supply to the Reader Controller from the Main Power Supply (Switching Regulator) is present. It is possible that one of the loads on the DC-Controller can take down the 24 volts. Remove the 24volt loads off the DC-Controller and connect the connectors one by one to locate the short or defective load.
Posted on Apr 19, 2009
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Canon Image Class 2200 Error code 0322 Can you help me with this problem It will not print at all
this means that you have problem with fixing assy. Best solution would be to replace fixing unit.
And,... did you consider to buying new one,... try with Canon image runner 3225N. Its a NORMAL copier. :-)
Jul 06, 2010 | Canon imageCLASS 2200 Black and White...
Error Code #E000602-003
0003 A sector fault is detected on the HDD.
You need to replace HDD, upload system, language,...
Call service, beacause all of above is done over service support tool.
Jun 30, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error Code E000002-0000
E002A start-up fault is detected under any of the following conditions of the main thermistor (start-up detection fault):
after exceeding 40°C, it fails to reach 60°C within 10 sec.
after exceeding 60°C, it fails to reach 80°C within 10 sec.
after exceeding 180°C, it fails to reach 195°C within 10 sec.
Jan 19, 2010 | Office Equipment & Supplies
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
How do I use the staples in the printer/copier?
Cannon image runner 2200 error code E000002-0000, how do solve this problem
Aug 22, 2009 | Canon imageRUNNER 2200
Image runner 3300 error code
it is a fuser film unit problem,thermistor is a poor contact (or) fixing heater is a problem.
do the following
press additionel function* button at once & press 2&8 buttons at a time and again press additonel function* button.
select COPIER>FUNCTION>CLEAR>ERROR>OK.
turn off the machine & on its again.
all the best.
Aug 09, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2200 Logo
373 people viewed this question
old marine
old marine
