Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Doesn't cool When our refrigerator is all the way inside the built in it doesn't cool.  We pull it half way out and it cools perfectly fine.  I am guessing we need to find a way to cut the built in closet for a big vent, but I want to make sure there's nothing wrong with the refrigerator first.
  • sunku1961 Apr 20, 2009
    My Refrigirator is not getting cool, Light also not come in Refrigirator
  • 125 Answers
Make sure the condensor fan is not blocked, or that the cardboard back/bottom piece isn't wrinkled and pushing up into the fan. the fan is located behind the cardboard panel on the back side of the unit, rt side.
Posted on Apr 18, 2009
Refrigerator is not cooling
Hello there,
If your refrigerator is not cooling, but is running perfectly, you will have to test the defrost thermostat, defrost heater and the defrost timer, when you test them, replace the faulty part and it will work perfectly fine.
If that does not solve the problem, then check the door switch. Make sure you check the refrigerator if it is still having gas in the cylinder. If there is no gas the refrigerator will be working perfectly fine but will never get cool.
Would be glad to know if this information was helpful to you. All the best Elect_Comp
Sep 26, 2011 | Amana DRB1901C Bottom Freezer Refrigerator
Refrigerator GE GTE18HBW(B)WW has compressor Samsung MK162Q-L1U.Compressor is running(current 0.5A),but does not cooling.Both fans is working.Electrical wiring checked. Other refrigerator has same...
Hello there,
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | GE Refrigerators
My Everest Freezer, Model ESF1, SERIAL BSF1-0106-0024, is not cooling at all; I can hear the fan working, but inside is warm. Do I need a new control board? what do I need? please advice. Thank...
Hello there,
If your refrigerator is not cooling, but is running perfectly, you will have to test the door switch, defrost thermostat, defrost heater and the defrost timer, when you test them, replace the faulty part and it will work perfectly fine.
Hope this helps. All the best Elect_Comp
Sep 23, 2011 | Everest Refrigeration ESR1 Refrigerator...
My fridge is running but not cooling
Hello there,
Sep 21, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
I bought a frigidaire refigerator in March, 2007, noticed recently it was getting warmer inside. Pulled it out to clean coils and saw a date stamped on back of fridge with the words fix 06 beside it. What...
It should be OK and not 06 as you mentioned. Please have a look again and reconfirm it. It says that the unit is tested and in good working condition a certification from the final check point of the unit at the factory.
The failure of cooling is due to refrigerant leak and I wonder whether you have moved the refrigerator from the original place of installation. During moving the fridge the condenser coil would have been touched and resulted in refrigerant leak and resulting in poor cooling or no cooling at all. This also would have taken place over a period of time and not instantly on a fine morning. By recharging the refrigerant your unit should cool perfectly.
Jul 14, 2009 | Refrigerators
Whirpool refrigerator, freezer fine, refrigerator warm
my suggestion give it up for the dead
Feb 23, 2008 | Refrigerators
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
