I want 2 pass assembler code in c or c++ - Computers & Internet
What do you mean by pass?
Depending on your compiler, you can inline assembly statements. For Microsoft Visual Studio C/C++ the syntax is:
__asm push eax
or
__asm {
push eax
pop eax
If you want to link to assembly routines that you separately compiled via an assembler... that is a little bit more complicated:
In your C or C++ program declare your assembly routine:
extern "C" { void __stdcall example(); }
This gives it standard C linkage (which will turn off name decoration), and tells your compiler that the function is external (i.e. won't be available until link time).
In your assembly file:
.386
.model flat
.code
public _example
_example proc
ret
_example endp
end
After assembling your .asm file, you will need to tell your linker to include the resulting .obj file. This varies by environment, but for Microsoft Visual Studio you can add it under Project Properties, 'Linker', 'Input', 'Additional Dependencies'. You may get linker errors, in which case you should double check your assembler options to make sure you are generating case sensitive names.
Posted on Apr 24, 2009
Give me a project's solution for 2 pass assembler support in SIC/XE machine and that can enables for program blocks,control sections,litterals
etc.
Posted on Jan 09, 2012
F1 code means what?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F1 and UL
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%#
Jun 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio is giving a code which is f1,
Jun 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio WTW6600SBT Top Load Washer: f1 error code on WTW6600SBT. It happens at the st...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@$
May 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F1
Apr 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F1
Jan 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code Whirlpool cabrio
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio top loader, F1 code
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WTW 66005W1 cabrio, F1 error code.?????Machine error code at start and during rinse cycle. What is causing this? Any quick fix?
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Apr 08, 2009 | Whirlpool WTW6400SW Cabrio Washer
Computers & Internet Logo
1,948 people viewed this question
David Payne
David Payne
