Question about NEC VT595 LCD Projector
Nec VT595 shows only wallpaper
Nec VT595 connected to HP laptop shows only desktop wallpaper
  • 259 Answers
It could be the laptop settings. You have to clone the output of you video card. You might have extended desktop setting selected. See if your mouse shows up when you scroll it across the screen. (go all the way left or right) . If you have questions you can call me 1-646-441-5254 Hope this helps.
Posted on Apr 14, 2009
Having a problem getting past the red blinking status and orange blinking when trying to start up a NEC VT595 projector. This is after installing a new bulb.
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
Jul 13, 2011 | NEC VT595 LCD Projector
How do you change the bulb for the NEC model VT595? I have two men looking at it and can't work out how to remove the old one.
Slide panel out half an inch. Using thumb and index finger squeeze end of cover and pull out
Jan 24, 2011 | NEC VT595 LCD Projector
Projector turns itself off after 10 minutes
Check the air filter and if it has an air filter counter, you may need to reset it.
May 13, 2010 | NEC VT595 LCD Projector
How do i reset bulb hours on a NEC vt595
Here is the user manual for this projector, It should help with all your questions.
http://www.projectorcentral.com/pdf/projector_manual_3467.pdf
Apr 21, 2010 | NEC VT595 LCD Projector
Lamp light stays solid red . i already replaced bulb. any solutions?
Check your owners manual for diagnostics. You can find all documentation for your VT595/695 projector on the NEC support site.
The users guide indicates that the lamp timer needs to be reset. Instructions can be found on page 49 of the users guide.
Press and hold the HELP button on the remote control for 10 seconds to reset the timer.
Feb 05, 2010 | NEC VT595 LCD Projector
My nec vt595 wont start up the status light is flashing orange
The only time the "status" light will be orange is when you accidently press the cabinet button and the cabinet is locked.
However, if the "power" light is blinking orange it means that the projector is cooling down and you need to wait a few minutes.
Jan 03, 2010 | NEC Computers & Internet
How do i change the desktop background on my hp mini 110-116nr laptop?
You cannot change the wallpaper in starter edition. The feature is not included, it has been designed for entry level pc's only. Like everyone else is saying the tab is not there and when you right click on the image and click add as background it does not work. The most current and simplest ways is to select and right-click on the picture you wish to set as the background image. You can leave protected operating system files hidden to not have the desktop.ini files displayed, but leave system files unhidden to see the rest of them. First navigate to: %SystemRoot%\Web\Wallpaper. That's pretty much it, place your wallpapers there, create new folders etc, and they will show in the Windows Desktop Backgrounds menu in wallpaper selection
Dec 23, 2009 | HP Pavilion dv5-1125nr Notebook
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
  • Try to right-click somewhere in the desktop, choose "Properties" and go to the Settings tab. (Now you should be able to see both monitors.)
  • Click on the "Identify" tab to see which one is your TV.
  • See if "Extend my Windows Desktop onto this monitor" is checked.
  • Try to find a resolution that works with your TV by changing the values for the screen resolution.
Jan 03, 2009 | HP Pavilion dv2000t Notebook
NEC VT595 LCD Projector Logo
289 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
