Question about Xtreme Sound WMS6100RW 10-Disc CD Changer
Will not come on , just say nd
Wired the system up, will not eject the cd changer.
  • 65 Answers
I think there is a "reset" button, push it a few times.
Posted on Sep 17, 2007
How to remove cd from blocked cd changer
To remove a CD from a changer that does not respond to the eject button: Look to see if there is a tiny round hole near the eject button. It will be as small or smaller than the diameter of a paperclip. If you see it then that is the CD release. You will need to find a piece of very stiff wire that fits comfortably in that hole. After you insert the wire you will feel it land against something hard in maybe about 1/2 inch. Gently press the wire and hope that there is compression of the switch which will open the CD Changer.
Jun 22, 2014 | 2003 Mercedes-Benz E-Class
Jensen MCDA1 10 CD Changer - CD cartridge will not eject.
Had the same problem. It's the microswitch/eject button-reset. The wires were-soldered.works fine.you actually have to remove the switch to inspect the soldering.
Jun 11, 2011 | Jensen MCDA1 AM/FM/MP3/ Stereo with...
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
May 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
Car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Nov 23, 2008 | Car Audio & Video
CD changer eject button does not work. Three discs are inside. Changer works. Good sound is produced. But unable to eject disc changer to change discs.
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Oct 27, 2008 | Curtis RCD-897 CD Shelf System
Can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Oct 26, 2008 | Bose Lifestyle 20 System
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Xtreme Sound WMS6100RW 10-Disc CD Changer Logo
65 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
