Question about Sylvania LC320SS8 32 in. LCD Television
Upon attempting to turn on my sylvania lcd tv lc320ss8 by either remote control or manually the red light goes green and flashes 6-7 times and goes back red with no picture or sound.
  • dhutch76 Apr 14, 2009
    in lay mans terms...is there a module/part that needs replacing...i did see 2 suggestions on line.
    first- the digital main board and second the transformer inverter board as possible problem areas.
    thanks
    by the postings on line this seems to be a common problem
  • Sylvania Master
  • 19,396 Answers
Sylvania are re-branded TVs , they distribute and re-tag TVs from Funai , Emerson and more.
Therefore the error code is associated with the single model, and you need a service manual if you want to know the meaning of the blink code.
Here a link to somebody with service manual.Service Manual. or ManualsParadise
Regarding your specific case, what a repairer will do is testing the TV , starting from power board, then proceeding on testing inverter and digital controller board that are parts that commonly fail.
Asking "what part I must change" is like typing "my car does not crank, what part should I change".
Even if you have the meaning of blinking code, you will need to test tv the same.
If you want to DIY get service manual from links above.
Posted on Apr 14, 2009
    Brigadier General:
  • 3,614 Answers
i assumed that the problem was a High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
hope this initial info/idea helps.
let me know for further assistance.
  • micromaster
    micromaster Apr 14, 2009
    check the power supply area using an OHM meter
My tv will not pwr up. grn light flashes then turns red.
I have a Sylvania LD320SS8A and I turn it on and the green light comes on and no picture???? Just black... I can hear some sound but no picture...
Feb 12, 2010 | Sylvania LC320SS8 32 in. LCD Television
Tv will not turn on
The green blinks are an error code indicating a specific fault, your power supply developed an 'over-voltage' issue and needs to be serviced at your local repair shop.......
Nov 02, 2009 | Sylvania LC320SS8 32 in. LCD Television
Television when turned on: light goes to green then flashes twice. green light goes out and red light comes on. tv will not come on.
If the Red Light Blinks twice and goes out, the TV is in Protection Mode. There are 6 voltage outputs to the lamps around the screen. If one of those outputs is missing the TV will sense that there's a problem and refuse to turn on. The predominant failure in this model are the output transformers on the Inverter board. A properly trained technician can measure the windings on each transformer and look for an open circuit, if one is found, replace that Transformer. i was given one of these sets from a friend and I replaced an output transformer ($11 w/shipping) and I now have a fully functional TV/DVD Combo. Also verify that all of the connecting cables internally are properly seated, there have been reports or the ribbon cables from the Power supply board to the main board above it not being fully inserted and it also prevented the TV from turning on. A word of caution. There are VERY High Voltages on the inverter circuit board, only persons with proper training and knowledge should attempt this repair.
Aug 30, 2009 | Sylvania LC320SS8 32 in. LCD Television
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
May 07, 2009 | Sylvania LC320SS8 32 in. LCD Television
TV won't turn on!
There is a common problem with Funai products. The transformer inverter board goes bad on these TV. Mine only lasted 4 months. Your still under warranty. So, use it to your full extent.
Feb 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
Jun 30, 2008 | Sylvania LC320SS8 32 in. LCD Television
Controlling my Sylvania LC320SS8 with my Dish Network remote
Try these Sylvania codes: 10054, 10030, 10171, 0030, 0054, 0171, 1944, 1963.
These weren't listed in Dish Receiver manual.
Apr 09, 2008 | Sylvania LC320SS8 32 in. LCD Television
Cannot program Direct TV to Sylvania 32"LCD TV LC320SS8
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
here are the code for your tv: Sylvania 10054, 10030, 10171
Dec 01, 2007 | One For All URC-3021 Remote Control
Sylvania LC320SS8 32 in. LCD Television Logo
103 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
