Question about HP Officejet Pro L7680 All-In-One Printer
Always going to auto feed not glass tray when trying to copy
    Problem Solver:
  • 6 Answers
Probably a torn peice of paper in the auto feed sensor flag,t he machine thinks there is paper in the auto feeder or check in the driver set everything back to defaults and try it,If problem persists contact hp support and chat with a tech online, they are great.They are more familier with the menu on your model.
Posted on Apr 23, 2009
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
Copying from upper tray - line on the copy - good copy but has a solid thin line, about the size of the roller.. -- copying from glass is fine..--if it is the roller ! how do I clean upper roller and etc....
hello, you said this was a copy, have you tried making copy from the glass, and not thru the doc feed, just to see if the output us the same. if not, open up the doc feed area, and clean the **** glass. now if your prints from the computer are the same as the copies, then its possible that the problem is pressure rollers above the ashpalt grey platten roller. alittle harder to clean but can be cleaned off.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I cannot get my copier to copy papers. Please refresh my memory on how the 5610 all in one copies. Thanx
We have a 6210 at work, must be similar though.
Make sure you have blank paper in tray, Put piece you want copy of face down on scan glass, close lid, hit copy, it takes a minute to wake up. Or put piece you want copied in auto-feed face up, hit copy, it takes a while to wake up, seems as though it is not working, then it will.
Jun 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Have a Samsung SCX-5315F All-In-One that has a line running down the page when you copy using the document input tray. Clean copy when using the flatbed. I have cleaned all the glass thoroughly.
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Feb 18, 2010 | Samsung SCX-5315F All-In-One Laser Printer
, line on copy when top feed tray is used
clean the small glass left of the platen ... you probably have some white out on it
Oct 22, 2009 | Office Equipment & Supplies
Auto feeder not working
Easy fix. Turn the machine off, on the back side of the document feeder is one beige cable. Unscrew the two screws and disconnect the cable. Turn the machine on with the feeder unplugged, let it come to ready. turn the machine off, connect the beige connector and turn the machine back on, It basically forgot it has a feeder and needs to plug and play without the feeder then to detect it when plugged back in,
Aug 13, 2009 | Xerox CopyCentre C20 Black and White...
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Automatic paper feed
The narrow glass section at the left of the flat bed scanner glass is shaped concave to route the paper back up to the tray if you are using the document feeder. Right above this is a spring loaded paper guide that puts slight pressure on the paper as it is fed through. If the cover of the scanner is not closing completely it will miss guide the paper. I would check that there is nothing on the flatbed or in the hinge section that is keeping the cover lifted slightly. The hinges do extend for copying books, so it may have jammed in the up position causing your problem. Good luck!
Sep 08, 2008 | Brother MFC-8840D All-In-One Laser Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
HP Officejet Pro L7680 All-In-One Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
