Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Blinking green light, no picture or sound
The TV was working fine then no sound or picture. The Timer light is blinking. I've tried the reset and it does not resolve the problem. I unplugged the TV for a few days and when I plugged it in it worked. After a few hours it stopped again and the timer light is blinking. Help.
  • 3 more comments
  • VA_Novice Nov 11, 2007
    Blinking timer light and system shut down even after restting and unplugging.
  • Anonymous Dec 13, 2007
    I have the same problem. My 62525 shuts down with blinking green light. Reset does nothing. Shutting the power off at the surge protector for at least 5 minutes will allow the TV to come back on but, often after 20 minutes it happens again. Another power off cycle usually results in the picture and sound returning for several hours before it goes off again.
    Have a tech visit scheduled two days from now.
  • catbone Jul 04, 2008
    I have the same problem the green timer light blinks and theres no picture or sound but evan when i unplug it, it still doesn't come on not even for alittle bit what do you think i can do?
  • Anonymous Jul 13, 2008
    I have the same problem too? Any hints on how to fix??
  • thewarner Dec 11, 2008
    I have Mitsubishi WD-52725 that went blank while watching HTDV then it reset and the Timer LED kept blinking. A POR did not fix the issue. The repair shop, supposedly trained by Mitsubishi is asking for 800$ to ship it to Mitsubishi for repair. He does not have a clue what broke in it... He is telling me it is the Chassis! Go figure! For that kind of money, I am dumping it. Mitsubishi is screwing up the environment!
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Posted on Jul 02, 2008
Probably the DM1 module has or is going bad.
Posted on Oct 18, 2007
Http://www.chrisandnat.com/temp/BlinkingTV.pdf
this may help,, haven't tried it but seems to be a solution for many with the blinking light problem. its worth a shot since the parts and soldering iron will cost you about 20 bucks..
Posted on Nov 02, 2007
SOURCE:
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
My timer light keeps blinking on my Mitsubishi-TV not watchable
tv is not locked up, you have a lot of capacitors that have gone bad on the boards that make up the chassis. We have been sending the chassis in to Mitsubishi to be rebuilt. Some people have been doing the capacitor changing themselves but, this is a very involved job.
Dec 03, 2009 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,247 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
