Question about Acer Aspire 1681WLMi Notebook
I have the aspire 1680. having problems switching on. power lead plugged in but does not switch on. removed battery and power lead put battery back in along with power lead orange led shows but still wont power up. unplugged power lead and plugged back in number of times and powers up. do i need to buy new battery or charger or can the problem be something else?
1984 HARLEY FXRD TOOK BATTERY OUT FOR WINTER PUT BACK IN SPARKED NOW NO POWER WITH KEY IS THERE A FUSE OR RELAY I MAY HAVE BLOWN WHEN IT SPARKED AND WHERE WOULD IT BE
under the seat i believe follow positive cable back large goes to solinoid and smaller one will go to a fuse when this is blown there is no power or starter
Dec 01, 2014 | Power Motorcycles
Acer aspire 5552
may be that the battery is fried so neesd a new one maybe
Mar 24, 2013 | Acer Aspire 5551 Notebook
I have an almost similar problem. When plugged in, the AC/ Battery LED indicator does not light up and I can't power up the unit. Sometimes when I take out the battery and put it back in, the unit powers...
Yes this fault is in the mother board but the fault is the switching/regulation/charging section of the pwoeer supply section.
Somehow it is not switched on auto and so the malfunction. Might have to remove and check the powerr section for errors in the regulator.
Sep 23, 2010 | Acer Aspire 4520-5582 Notebook
I have an ACER Aspire 5052AWXMi. The battery is drained as I was trying to charge it while the battery was running down but it didn't work. The battery is fully drained and my charger (and friends'...
had this problem with a friends, you may have to update the bios, acer know about the problem with the batterys, flash the bios with the update, turn the laptop off remove the battery and switch it on using the plugged in power, now put the battery back in while its on, leave for 5-10 minutes and it should then start charging. its a fault with the acer one's
Sep 03, 2010 | Acer Aspire One PC Notebook
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
May 10, 2010 | Acer Aspire One PC Notebook
Acer 5570 - Power switch is not working
Try removing the power supply (from the wall) and the battery pack. Hold down the power button for 30 seconds. Plug the mains power (from the wall) back in and then press the power button. It should work. Then you can replace your battery pack. Don't know why it works but it has worked for me in the past. Good luck!
Aug 01, 2009 | Acer Aspire 5520-5908 Notebook
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
Screen
remove the battery try pressing the FN key and F4, F5, F7 (which ever your lap uses to switch between external lcd and internal screen)
Aug 31, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 1681WLMi Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
