Back to:
Tags:
Acer TravelMate C110 Tablet PC
Audio feedback
posted by k-rose on Sep 13, 2007
The built-in microphone and the built-in speakers cause audio feedback at normal volume settings. Are there settings for either the microphone or the speakers that will avoid this? Muting the speakers works, but I'd like to not have to do that.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 03, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi , If your still having problems with your C110, try Double clicking on the volume control speaker in the task bar in the lower - right corner of your desktop. When the volume control box opens , check the mute box on the line in control . I also mute the mic, and the phone line control if you have one . See how that works for you. I really notice the feed back when I use headphones.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Audio feedback:
I don't want to Accept this solution
Solution #2
posted on Feb 04, 2008
Not Rated (0)
melnavz
Rank:Guru Guru
Rating: 85%, 524 votes
this maybe was cause by a grounded connection.
Please try put a grounding wire from your stuff to the ground. this elimanate noise.
if this not work, do not rate me instead notify me for another solution im online 12 hours day.
Thank You!
Can you Help with these Tablet PCs problems?
Tablet PCs
how to share drives between linux and xp installed on a...
Please tell me where to find a cmos battery for the acer...
Tablet PCs
dear experts, please help me install my a4tech pk635...
Tablet PCs
I just bought a tablet Genius F350and I use it with Vista....
I don't use the external drive very much but am finding...
Loading problems.
Repair Service
Find Tablet PC Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
