Question about Acer Aspire 5500 5570-2609 Laptop
Won't booting and lcd blank...
After i setting up battery my laptop won't booting and lcd turn blank lamp indicators of hardisk just light first time after start...thanks
  • gastonlink Apr 20, 2009
    I have the exact same problem. I was working on the computer with just the battery when I got the message that I needed to plug the computer in. I did. When I finished I left the computer on and plugged to charge. I returned to the computer after 25 minutes and the entire screen was black. The computer is not connecting to the hard drive at all. The "boot" button only lights for a second when I turn the computer on. I cannot reboot because it is not showing anything on the screen.
  • JEFFrey BAKER
    JEFFrey BAKER May 11, 2010
    DOES THIS HAPPEN WHEN YOU PLUG THE COMPUTER INTO A OUTLET WITH THE CORD ?
Boots up but black screen
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1.Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2.Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3.Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4.Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5.Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
Sep 05, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Not booting from xp cd
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Dell Inspiron 9400 Notebook
Dell optiplex not booting from xp cd
Aug 15, 2011 | Dell OptiPlex SX270 PC Desktop
HP Pavilion dv7-1129wm blank screen upon booting of machine
Jun 16, 2011 | HP Pavilion dv7-1129wm Notebook
My ibm a21m turns on with the little light as well but nothing happens the screen is blank the hard drive powers up still nothing need help please
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 30, 2009 | IBM ThinkPad A21m 2628 Notebook
The led of harddrive is keep on lighting, no screen signal (laptop model lw40 of lg)
Does the laptop appear to boot up but the screen remains blank?
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 30, 2009 | Computers & Internet
Blank screen when booting a t30
You could have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 07, 2009 | IBM ThinkPad T42 Laptop
Compaq V3424au that has a blank screen on startup with all lights
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Compaq Computers & Internet
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
