Copiers
Problem for Copiers
Generic problem for all Copiers
Suddenly I am getting an error code E00...
By atherayub on Apr 14, 2009
Suddenly I am getting an error code E0004 on my np8530 copier and then adp stop working, please solve my problem :(
Comments:
Apr 14, 2009
- Thanks for reply Bob,
Brother I can do all steps as you said, but when Key up to 13, the copier read out error, then press * key, copies did not reset and give same error.
the copier is working properly, but just only PDF cant work like before.
Please help me if any solution,
waiting reply
THANKS
ATHER
Apr 14, 2009
- Dear Bob ,
One More is that, The copier sorter is off and machine paper option cannot going on AUTO PAPER select, If any solution please send.
Regards
ATHER
Apr 15, 2009
- Dear Bob
I told you all story, i bought recondition NP8530 in working condition with all systems working (ADF, DUPLEX, DEC ETC).
One day I make copies from ADF then suddenly paper jam in ADF and machine give "error E004, and restart the machine", I restarted the machine then error go away and did not come back. but ADF is off and also "AUTO paper option" is off.
I noted one thing a one option is off which is on LEFT SIDE MACHINE : NAMELY
SORT
STAPLER SORT
GROUP
The above option was on when i purchase the machine, but now it is off.
I think any code or any option is off in my machine,
Now I hope you understand my problem.
Bob, I am very disturbed till my ADF close, Please make solution I will be very thankful to you.
Regards
ATHER
Apr 17, 2009
- Hi Bob,
i make a machine video and sent you link by sms. Did you see the video, if not please click on the below link and see what is the problem then tell me the solution. and please also sent your email
http://www.youtube.com/watch?v=x4-We97lOu4
Waiting your reply
Apr 22, 2009
- Dear Bob
My problem is still same as before , I swear, still ADF cannot work and paper mode cannot go on AUTO PAPER.
I am making another video and will send you
I need a solution
Solution #1
posted on Apr 14, 2009
Not Rated)
hinderschied
Rank: Guru
Rating: 93%, 42 votes
It's an E-004, this has to do with your fuser unit.
The hot rollers in the exit of the machine.
Inside the front right door, half way down on the rightjam indicator panel with a screw at the top.
Remove that screw to expose a circuit board, there is a little green circle push switch, press that switch and a dollar symbol will appear on the control panel. Now press *4* on the control panel,
using the plus button under the flip panel for reducing and enlarging one percent increments, press the plus key up to 13, the copier will read out error, then press the * key to reset.
It will probably come back because of a bad connection or a blown fuse in the fuser unit, or it will be fixed.
Thanks
Bob
Comments:
Apr 14, 2009
- Hi Ather,
I'm a little confused with your reply, after hitting the * key did the E-004 go away? Then later you say the copier is working properly but just only the PDF can't work like before. Is that the large paper tray on the lower right? If the copier was copying when it went into the error code after you reset the code it probably has paper jammed inside it and you will have to clear the jam before it will try to come ready again.
The large capacity tray will lower the paper if it is a jam state.
Good luck with it.
Thanks
Bob
Apr 16, 2009
- Hello Ather,
Sort
staple/sort
group
These are sorting options with a push switch to go to different modes. do you have a sorter attached to the left side of your copier or is there just a tray that the copies come out and lay on.
There are 2 power supplies in your copier one works the copier main body the other supplies power to the accesories such as the ADF, the paper deck, the sorter and I believe the duplex unit?
I don't know what else I can tell you by writing back and fourth. I found your last post this morning because it did not go to my inbox it went to the spam box. so I'm sorry I didn't get back to you sooner. You can call me at 561 319-8253 and maybe we can walk thru your troubles over the phone.
Thank you
Bob
Apr 16, 2009
- Hi Ather,
I forgot the most basic thing when it comes to these machines when they get confused.
Turn the machine off then unplug it. Leave it unplugged for a couple minutes, plug it back in and turn it back on.
Good luck
Bob
Apr 17, 2009
- Nice video! Reset your dipswitches on the feeder circuit board to off. Turn off the copier and then unplug it. Wait a couple minutes then plug it back in, make another video. Remove all the paper from the feeder stand back away from the copier with the camera to show a whole view of the entire machine and let me see the copier go thru its warm up procedure. Then have someone put in some originals to be copied hit the reset key a couple times and then press the start button and let me see what happens.
Thanks
Bob
Apr 21, 2009
- Hi Ather,
Please come back and rate my help, I know it'sworking again.
Your feeder wasjust in a test mode and probably got there by trying to clear the error.
I would greatly appreciate a rating from you.
Thanks
Bob
Apr 22, 2009
- Hi Ather,
I watched the original video again, right next to the button he pushed to manually check the doc feeder is the row of dip switches used to do different operations with the document feeder.
All of those dip switches need to be turned off and that will fix your trouble.
Let me know and good luck
Bob
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
"Check document. Open the ADF" This code is constantly displayed. I don't have the owners... (More)
Answer
Dirt under the glass
Answer
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to... (More)
Answer
where can I get a scanner chip for a panasonic workio 1820
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
