Question about Canon NP 6050 Copier
I am getting an error code E0004 on my np8530 copier
Suddently I am getting an error code E0004 on my np8530 copier and then my adf stop working :(, plesae solve my problem
  • 1 more comment
  • Anonymous May 24, 2009
    Thanks for reply mr sunilratlam
    Below is video my machine problem, the auto paper option did not work and also sorter is off
    Please see video and tell what is the problem ?
    http://www.youtube.com/watch?v=x4-We97lO...
    waiting yoru earlist reply
    regards
    ATHER
  • atherayub Jun 07, 2009
    Please see the Video again Motor Sensor is working porpely but when the ADF conntes is not working adf connection means the jeck benhind the mechine
    Thanks
    Thanks
    Sergeant:
  • 199 Answers
There are a motor sensor does not work properly
Posted on May 22, 2009
  • Sunil Rathod Jun 08, 2009
    You need some change in the option menu of copier, cureenlty I don't have sm and can't remember proper, but I think it's like APS and other setting.
    IF error code displayed again after connect the ADF, that means your adf has some sensor related problem
ADF cover is open
Sounds like a sensor is broken. Whatever caused the initial errors was not fixed and continued use has permanently broken the product.
Mar 16, 2015 | Brother International Inkjet Multifunction...
Amber light on no panel error code ADF stops working.
there a small pieces of paper in the paper path of the ADF by the paper jam sensor.
Nov 12, 2013 | HP LaserJet 4730mfp All-In-One Printer
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
E0004-0001
A E0004-0001 is caused by the fuser unit... Have you lost power resently? The code will need to be reset in service mode... Good Luck
Sep 30, 2011 | Canon imageRUNNER C3170U Color Copier
There is an error in imagerunner 6570 copier E0004-010 it is resolved then Error E00004-0103 occur. What would be the solution. What is the complaint?
press the [shutdown]key. After the machine has been shutdown turn the main power switchon the main units right side
[shutdown]
if the machine still does not operate normally contact your service representative with the error code below
E000025-0001
Sep 06, 2011 | Canon IMAGERUNNER 6570 Copier
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Suddenly I am getting an error code E0004 on my np8530 copier and then adp stop working, please solve my problem :(
It's an E-004, this has to do with your fuser unit.
The hot rollers in the exit of the machine.
Inside the front right door, half way down on the rightjam indicator panel with a screw at the top.
Remove that screw to expose a circuit board, there is a little green circle push switch, press that switch and a dollar symbol will appear on the control panel. Now press *4* on the control panel,
using the plus button under the flip panel for reducing and enlarging one percent increments, press the plus key up to 13, the copier will read out error, then press the * key to reset.
It will probably come back because of a bad connection or a blown fuse in the fuser unit, or it will be fixed.
Thanks
Bob
Apr 14, 2009 | Office Equipment & Supplies
Error Code : E000400-0100
The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB
Feb 16, 2009 | Canon imageRUNNER 5000 Copier
Canon NP 6050 Copier Logo
202 people viewed this question
old marine
old marine
