Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Can't install the solution disk
Whenever i try to install the solution disk (version 30) a message pops up on my computer saying "screen resolution to execute is not sufficient". However, i had the powershot sd630 and installed the solution disk just fine. Please help, I am frustrated beyond belief! Thanks Emily
  • 6 more comments
  • jazzle Dec 25, 2007
    Same problem.
    But I don't know what resolution it needs to be changed to...
  • Anonymous Dec 26, 2007
    I'm having the exact same problem. I changed the resolution a couple of times but that didn't change the problem. I have sent an email to Canon for help. Like the camera, but may need to return it.
    I'm having the same problem. I have tried changing the resolution but that doesn't help. I think the software is faulty. I email'd Canon for help
  • abo shlomo Dec 27, 2007
    screen resolution is not sufficient
  • Anonymous Mar 02, 2008
    Yes, I think the software is faulty!
  • Anonymous Nov 19, 2008
    cannon selphy es 30 error: the screen resolution to execute compact photo printer solution disk is not sufficient
  • fisherodjig Jan 01, 2009
    I cannot load the solution disk either. I have changed the resolution and still cant install.
  • Anonymous Jan 20, 2009
    same problem here and i have an hd monitor
  • 641 Answers
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Posted on Sep 13, 2007
I cannot install 30.0 version for my new A 460 canon digital.error-error-ZoomBrowser EX 5.8
Posted on Nov 19, 2007
3 Suggested Answers
  • 4738 Answers
SOURCE: can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Posted on Apr 12, 2008
I cannot install the software, its says: screen resolution to execute is not sufficient. Please what I do?
gr JP
Posted on Nov 22, 2008
Get my old version back
- Do you mean yahoo!classic?If so,try this:
- First you must operate from a CRT monitor.
- Set the screen resolution to 800x600 pixels.
- Open yahoo mail.
- Try to open any mail in your inbox.
- A screen resolution problem message pops up.
- Under this message is the return to the previous version of yahoo mail on that.
- Enjoy yahoo!classic again!
Sep 16, 2011 | Yahoo Computers & Internet
My screen resolution.... i cant see the objects below whenever im using some software
Hello, and thanks for using FixYa.
seems like either the Graphics card drivers are not installed or then you just have a small resolution in use. I suppose you know where you can adjust the resolution? But in any case its, right click on desktop and select properties / OR personalize / OR screen resolution, depending on which version of windows is in use. Then either slide the resolution to a higher setting or select one from the list.
If you can't adjust the resolution higher answer the following questions.
  1. do you get a error message?
  2. what is the brand and model of the machine?
  3. what windows is installed?
  4. do you know if all the drivers for the machine are installed?
Oct 17, 2010 | MSI Computers & Internet
I cannot play naruto video on my computer when i watching it on line, some message pop up, the message say '' the requested video cannot be display in your region'' what should i do?, i already install...
The video which you are trying tho play,its resolution is much more than that of your computer screen to fix your problem try another player or change the resolution
May 25, 2010 | Computers & Internet
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot instal RCA Opal m4002
Get an updated version of the software from RCA's website. Windows XP Pro and Mp3 players in general don't mix well - on a networked business system, Mp3 players are seen almost like hostile, foreign antibodies.
Apr 27, 2008 | RCA OPAL M4001 MP3 Player
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
716 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
