OUR XP SYSTEM IS NOT BOOTING COORECTLY WHILE BOOTING IT SHOWS FOUR MODES LIKE SAFE MODE WELL KNOWN OTHER MODE ... .... LIKE THIS IF WE SELECT ONE OF THEM AGAIN IT COMES TO THE SAME OPTIONS IT SAY BECAUSE OF SOME CHANGES IN SOFTWARE OR HARDWARE IT CAUSED IS I NEED TO USE A BOOT UP DISK TO OPEN OUR SYSTEM.OR ANY OTHER WAYS ..??PLS I NEED HELP
  • 489 Answers
Boot into Safe Mode. If it does this successfully, you will need to revert to a previous restore point or uninstall whatever hardware or software caused the problem in the first place. If you cannot get it to boot into safe mode, you may have to resort to using system recovery (provided it isi enabled on your computer) or a reinstallation of XP (at a minimum).
Posted on Apr 14, 2009
  • 33 Answers
You will need to either do a repair on your windows XP installation or a clean installation. If you choose to do a clean installation of windows XP then you may loose all your information on the PC.
You will need the Windows XP CD in order to do the repair or the clean install. It is advised to take the system into a service repair center for them to do this for you or if you do not have the windows XP CD.
Here are instructions from microsoft that may help you complete this process;
http://support.microsoft.com/kb/316941
Thanks
C
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
Compaq nx6120,screen went blue with instructions which it prevent windows from logging on
Trying booting into "Last Known Good Configuration" or safe mode by pressing F8 as soon as your system boots. If you can get into safe mode without the blue screen, your can perform a system restore to the date before the problem occurred.
How to restore Windows XP to previous state description of the Safe Mode Boot options in Windows XP
Jan 07, 2014 | Computers & Internet
MY ASUS F80Q WONT start up, it stuck in the Microsoft corporation
Hi. First option: For that symptoms try restart PC then before booting press F8 to see.(for windows xp professional and home edition. operating system )
safe mode safe mode with networking safe mode with command prompt enable booth logging enable VGA mode last known good configuration (your recent settings that worked) select this option by highlight then press enter key. if same problem? restart PC again then select safe mode wait for booting. already use that option not yet happened same problem. jimmyverdade_46.jpg
Second option:You need to reinstall fresh installation of operating system like windows xp,windows vista,windows 7 version etc.
Hope can help you.
Jun 17, 2011 | ASUS F80Q-X2AM Notebook
Wont start but xp logo appears then no more
Can you boot into safe mode? It sounds like your issue is a bad video driver- Try booting into Safe Mode by tapping the F8 key and selecting safe mode. Reinstall your video driver and try rebooting. There is a specific issue where if the video card has gone out, you will get symptoms similar to what you are experiencing. If reinstalling the driver does not work- try replacing the video card if possible
Oct 03, 2010 | Computers & Internet
XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Oct 26, 2009 | IBM ThinkPad T60 Notebook
My computerr will not load its comeing up with configaration problems
Try booting in safe mode and shut down properly and then try again, if this doesnt resolve the issue format and reinstall windows operating system
Oct 03, 2009 | Microsoft Windows XP Home Edition
PC notebook will only start in safe mode.
Try doing a System Restore, once you have booted up in Safe Mode, to a time before you had the problem.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | Computers & Internet
Unable to boot the computer
start the sys and press F8 KEY to go to safe mode.
then run chkdsk
Apr 03, 2008 | Microsoft Windows XP Home Edition
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
