Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Service Manual Techman, On July 11, 2007, mtsanch gave you credit for the solution to his capacitor problem. I have the same problem he described. I would greatly appreciate it if you would forward me the service manual for accessing the power supply board to replace the capacitors. My email is [email protected] Many thanks.
  • 6 more comments
  • vadodio Nov 15, 2007
    Fixya is great! My problem with my Mits WD-52525 was described on Fixya. Techman gave the solution - blown caps on the power supply board. I purchased and downloaded a service manual and ordered caps from Mitsubishi. My brother-in-law has worked with power supply boards and did the repair. Yeah, we had a few extra screws left over when we put it back together, but the TV is working! Thanks to you and a couple of folks who sent me suggestions.
  • Anonymous Nov 27, 2007
    I have the same problem he described. I would greatly appreciate it if you would forward me the service manual for accessing the power supply board to replace the capacitors. My email is rhodavid@gmail.com.
  • monseman Feb 09, 2008
    I seem to be having the same symptoms as well. Could you send me the service manual at [email protected]?
    Thanks!!!
  • 1stTimer Feb 11, 2008
    I seem to be having the same symptoms as well. Could you send me the service manual at [email protected]. Started disassembly but got stuck. Maybe I should get an otter to open this clam. {:^)
  • Anonymous Feb 13, 2008
    I CHANGE THE CAPACITOR OF 3300 mf AND WORK FIVE MINUTES AND TURN OFF AGAING WHAT I CAN DO?
  • ccjccre Aug 27, 2008
    I have the same problem. I have part of a service manual but it does not show how to get to the power supply. Help with a manual if you can.
    Email to [email protected] Thanks
  • nils Sep 08, 2008
    Hi I have a bad dm module,anyone have a copy of the service manual so I hopefully can repair this DLP
  • deuro May 11, 2010
    do you mind to forward the service manual to [email protected]? i really appreciate your help i been have so menny problems with this wd52525,thank you!!
I may have what you need. I have mine apart all over the floor right now. This is how I learned about cars too. Finding blown capacitors but not the 1000/16v ones, but then I am just digging into the power supply. Will forward what I have.
Posted on Sep 15, 2007
  • noseriously Sep 15, 2007
    BTW, breaking this thing open is tougher than a one armed otter opening a clam. Been debating about replacing what I see now and putting it back together or spend the rest of tomorrow to check the other boards.
  • noseriously Sep 18, 2007
    Fixed it. Turned out to be 3300/10v capacitors on the power supply. Symptoms were a harsh horizontal and vertical scroll which eventually went black. Had audio. Strange deal was that as I went to switch devices it would shut off and I got the solid red light.
    Replaced both caps and it works fine. Thanks to all on this web site.
6ya staff
SOURCE:
I have two charges on my bill. What is a virtual charge
Your question is incomplete. Please add details using the Comment menu choice.
It sounds like your credit card bill, perhaps you paid "virtually", that is, not in person, and gave the credit card number and made authorization over the phone or using the internet, but without handing over your credit card in person.
Check with your bank or credit card company.
FIXYA did not bill you. It is a free service given by unpaid volunteers who live all over the world, using the internet.
May 14, 2018 | Computers & Internet
Can caps isue cause tv not to come on at ll. no lights no click sounds nothing
Defective capacitors can cause all kinds of faults, so, yes, your capacitors could be the cause of the fault you describe. Replacing such capacitors is not always easy, because manufacturers sometimes use multilayer circuit boards where the contact is in an inner layer of the PCB. However this is not always the case. If he PCB on which the defective capacitors are located can be removed it may be a relatively simple job for someone skilled in the art of soldering to replace them. Otherwise, it is a job for a professional TV repair technician. It may be possible to replace the card with another, or to take it a Samsung service centre for repair. You are likely to discover that it is easier or cheaper to buy a new TV,
There may be other problems with your TV that is causing it not to turn on.
27.July.2014
Jul 27, 2014 | Samsung HLT6187SAX 61" DLP HDTV
I entered my problem about July 5, paid my $12 by credit card, and have heard nothing at all. Please confirm that the $12 will be credited back to my credit card.
You need to report this to the resolution center. As this is time bound do it at the earliest.
Regards.
Plz. dont forget to rate this suggestion.
Jul 15, 2011 | Concord Camera Eye-Q Duo 2000 Digital...
It started to smell and then started to smoke last July I haven't turn it on since.
If you didn't haven't had the unit serviced and repaired since last July, now is the time to do it. With what you described, I seriously doubt, that the problem solved itself.
To find an authorized Frigidaire service provider in your area, click on the following link.
http://www.frigidaire.com/servicelocator
May 31, 2011 | Frigidaire FAH125P2T Air Conditioner
Techman
If you have no high voltage it could be hori output and Flyback Transfomer.squealing noise is a bad capacitor 470uf 16v
Sep 24, 2008 | Televison & Video
WD-52525
You will need the service manual to do this repair. I happen to have it, as this site was suppose to put in the pictures and things to explain that a lot of TV sets are still using this DM board, but they are building them differently. Just follow the directions in the service manual on how to remove the DM board and then follow the directions in the article on repairing the DM board. I will need your e-mail address to forward this service manual to you. Good Luck
Jul 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
TV Turns Off
this post belong to "rozco" whos that?...good luck
Aug 07, 2006 | Samsung HCJ552W 55" Rear Projection...
Techman
Not unless you have a magic wand!!!lolol This happens alot when a service man goes out to the house as they are told not to do many repairs in the home cause theres no money in it . If the set is over 3 to 5 years old it might not be such a stupid idea of looking into another set. Good Luck
Aug 02, 2006 | Sanyo AVM-3659S 36" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
