Question about Refrigerators
I need a new gasket for the door.
My United Comercial heavy duty 19.6 upright freezer needs a new gasket for the door and I can't find one. Serial # 005287381b type f55c-burw252 model UCFF 201
  • bamnott Apr 14, 2009
    I don't think it is a sub zero freezer. It is just a regular house hold freezer. I don't know what link you are talking about to go to the parts page. Could you recheck this for me?
    Thanks alot for your help!!!
    Hi again,
    I am wondering if there are any measurements for the freezer door gasket that you located in the parts order page??
    Also if it doesn't fit can it be returned???
    Thanks,
    Brenda
  • 294 Answers
HELLO IF YOUR BRAND IS A SUB ZERO THEN HERE'S A PARTS LIST FOR ORDER INCLUDING A DOOR GASKET http://www.repairclinic.com/Sub-Zero-Parts?s=t-UCFF+201+-%3d%3db114 IF ITS NOT A SUB ZERO WITCH THATS WHAT IT BROUGHT UP FOR YOUR MODEL NUMBER THEN YOU CAN DO A SEARCH ON THE PARTS PAGE FOR THE WEB SIGHT THAT I JUST PUT A LINK FOR UP ABOUVE
Posted on Apr 14, 2009
  • 1 more comment
  • JEFFrey BAKER
    JEFFrey BAKER Apr 14, 2009
    HELLO IF YOUR BRAND IS A SUB ZERO THEN HERE'S A PARTS LIST FOR ORDER INCLUDING A DOOR GASKET http://www.repairclinic.com/Sub-Zero-Par... IF ITS NOT A SUB ZERO WITCH THATS WHAT IT BROUGHT UP FOR YOUR MODEL NUMBER THEN YOU CAN DO A SEARCH ON THE PARTS PAGE FOR THE WEB SIGHT THAT I JUST PUT A LINK FOR UP ABOUVE
  • JEFFrey BAKER
    http://www.repairclinic.com/Sub-Zero-Par... HERE IS THE LINK TO THE REPAIRCLINIC APPLIANCE PARTS ORDER PAGE
  • JEFFrey BAKER
    NO IT DONT GIVE THE MEASUREMENTS FOR THE GASKET SIZE BUT YES THAY DO HAVE A RETURN POLICY FOR ANY REASON WITH IN 30 DAYS, I'VE ORDERD DRYER PARTS FROM THIS PAGE FOR MY OWN DRYER THERE PRETTY GOOD ABOUT THE SHIPPING TIME AND PRICE
Can I lay down an Imperial Heavy Duty Upright Freezer for transport in a van or must it be upright in a pick up?
It should be upright, but if you must, after standing it up again - don't plug it in for couple of days. When it's down, oil in the pump moves quickly, but when it's upright again it takes it's time. If you plug it in too early, pump will overheats and you will need a new pump. Hope it helps.
Apr 30, 2014 | Freezers
Need seal for center door for comercial 3 door Delfield.
A good parts store will carry ready made gaskets, just bring a sample to match.
Apr 28, 2010 | Freezers
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Sears Upright freezer-the door does not have the suction anymore
You may need the hinge adjusted or a new door gasket but you might first try putting a layer of vaseline on the gasket. If none of those things help the problem is probably other than the door seal.
Dec 05, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
387 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
