Try holding down the power key to force it to power off. Power it back up again and you should get the Windows Resume Loader with the following options "Continue with resume" and "Delete resume data and continue with startup". I can't remember the exact wording of the options, it may be different but you need to select the later or second option "Delete resume data and continue with startup".
SOURCE: Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
its generally due to static stored in the notebook ....which stuck the turn on process of the notebook...
turn off the notebook ,, remove the battery .. press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on the notebook it will start ,,,
if it not check in the safe mode
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
