Where is the batter on a Meridian 204 tuner
Battery replacement for Meridian 204 Tuner where is it and how to access
A 3.6 volt 150 mAmp/ hour NICAD battery is soldered to the bottom PCB Com board
Posted on Apr 15, 2009
The antenna port is broke off on my lg flat screen tv how do i fix it
It's possible to resolder the port back on but the tv will have to be pulled down to gain access to the tuner and tuner cover will need to be removed to resolder the signal wire where it's broken off the tuner board. In some cases the tuner needs to be desoldered and removed to get access to the tuner board. If your soldering skills are not great an alternative solution would be to use an external set top box. This can be a pest because you then need a second remote to change channels.
Jan 14, 2017 | LG Televison & Video
How can I set my phone to display percentage of battery usage
If it's an iPhone, there is a setting you can turn off and on to show the percentage of charge your battery has left. You can also get an app to tell you that and more.
Feb 16, 2016 | Apple iPhone Cell Phones
Martin LXME, Tuner Is Not Working!!
Hello
The set have electronic tuner inside. If the tuner has some fault, or it do not get proper voltage to tune in, the fault you reports here can occur. As the set is new, and only one month old, it will be best to get this set repaired by the authorised service center, as it will have warranty. If you try to open and repair ths set, the warranty will void. OK.
Jan 23, 2012 | Audio Players & Recorders
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Tuner
the answer is yes. Once you get another tuner, simply use soldering iron to remove the old turner from the TV panel board and replace with another.
Good luck.
Apr 18, 2010 | Emerson SB350 13 in. TV/DVD Combo
FRONTECH TV TUNER MODL JIL-0606 CODE 10 DOESNOT START
How to configure Remote control in my TV tuner card Model No. JIL - 0606
Jun 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tuner
whats wrong with the old tuner? did the connector break? depending on the damage the connector can be replaced to replace the tuner right out i would call a medium difficult level. it invovles removeing the signal board the board with the tuner on it simply unsoldering and replacings care should be taken not damage surface mounted components. at the shop it is possible we repair these tuner which involves opening the can tuner and soldering a new connector to the can of the tuner.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi FT-5500 Mark 11 AM/FM stereo tuner. It is a hi fi tuner and it has lost its ability to remember stations
Send me a copy of a manual and I tell which part to replace to fix this problem.
Regards
wojtektl@yahoo.com
Oct 11, 2008 | Audio Players & Recorders
Tuner wont save settings
Hi Matt1983,
You must have Battery + power on both the Yellow wire at all times. To get the Radio to operate, you need power on the red and yellow wire. Battery neg(-) is also imprtant, Besure your Black wire is definitly connected to the frame of the care and you can read voltage from the supply power to the black wire. Sometimes you have to remove paint from the area you connect the Black wire.
Nov 22, 2007 | Dual XDVD8181 Car Video Player
343 people viewed this question
 Grubhead
Grubhead
