Question about HP Pavilion a305w (DM181AR) PC Desktop
CPU START BUT NO SIGNAL ON MONITOR
I hv removed both the RAM. no beep sound.but swapping both the ram the monitor shows the signl...why?...
  • cap722 May 22, 2009
    I have no beeps , does not seem to go thru the post.. video shows a signal but no picture ,,,, there is power to the pc and monitor what may be the issue?
  • 700 Answers
It could be your ram edge connector is dirty, clean it with soft eraser.
Posted on Apr 16, 2009
Problem: No signal to desktop monitors
You have a hardware virus, on the motherboard sounds like and let me guess, do you use WMP windows media player, and also do you have a phone hotspot, if any of this is true, you have the same as I did, message me or comment now I am on line.
Mar 07, 2016 | Computers & Internet
Changed cpu on packard bell imedia d3318, still getting no signal on monitor and no beeps. When I remove the cpu and power on, there are no beeps
Have you check with different RAM, Did you try to reset BIOS by removing the CMOS battery and shorting CMOS jumper? Your Processor may be ok but you are plying with it. When there use to be no display then first thing you should doubt with the CMOS battery and the RAM and Motherboard, rather then CPU, CPU hardly gives problem.
Aug 14, 2012 | HEWLETT-PACKARD Computers & Internet
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
No display no beep sound
you need to check your memory RAM of your PC. if it is ok or not. try to swap to another pc or tighten it.. cheer ^^
Jul 20, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
Computer on can't see screen
There seems to be either an LCD screen problem or the LCD inverter board. This issue needs to be properly diagnosed by a technician.
Mar 03, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Monitor beeps when turned on no picture
disconnect signal cable if monitor show massage no signal check signal cable then monitor is ok then open cpu check whether dust is in ram then clean the dust and again fit the ram the problem will be solved if not then disconnect ram listen beep and if contineus beep comes then motherboard is ok if no beep then motherboard is faulty replace it
Nov 26, 2008 | NetTV DTV 34XR 34" CRT Monitor
HP Pavilion a305w (DM181AR) PC Desktop Logo
142 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
