Question about Garden
LOW VOLTAGE @ STARTER ON CUB CADET MOWER
I HAVE A L1042 RIDDING MOWER. LOW VOLTAGE AT STARTER. I HAVE REPLACED BATTERY, STARTER, AND SOLINOID. STILL HAVE BUZZING AT SOLINOID.
  • 205 Answers
Check for good connection on the Ground wire
Posted on Apr 15, 2009
Where are fuses located on Cub Cadet Lawn mower?
Open up the cowling and the fuse is located to the right of the battery. It is a european style (flat) fuse as shown:
The yellow fuse shown below is the only one on mine.
I have had this Cub for years and have never replaced this fuse.
Depending upon how old the mower is you may want to:
1. Check the condition of the battery. I keep mine on a trikle charge over the winter. The battery may need replacing. Using a voltmeter to check battery voltage.
2. Check the battery cables to ensure that are secure and not corroded.
3. You may want to check the starter and ensure good conntion.
4. In general check all electrical wire connections.
Anything else I can help with please advise.
Aug 04, 2014 | Cub Cadet Garden
What size battery for cub cadet 2006 cub cadet
Most machines will have a negative earth, this is normally a black wire , follow the wire , it will be screwed down to eart against the chassis, the live wire will be red, follow this wire and it will go to the start solinoid, there may also be a low tention wire from the live terminal this will have a fuse somewhere in it,
Mar 04, 2012 | Northern Tool Lawn Mower Battery 12 Volt,...
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet 2166 . When I try to start it, the starter drive throws up, but won't turn the engine. I took the starter off and when you turn the key to start, the drive throws up and turns slow...
Can you measure the voltage of the battery? If you are getting low voltage then the battery needs to be charged or replaced, if the voltage is good then you probably have a bad starter. It might be something you can see like shorted windings on the motor.
Jun 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a Craftsman LT 1000 17.5 hp. replaced the battery and cleaned all the cables but it only will turn over once then seems like the battery is dead but in a minute or so it will turn over 1 time again
Sounds like your starter is weak or either your making poor contact across your solinoid. Try the solinoid first and if that doesn't fix it then try the starter.
Jul 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
