Question about Canon CP1213DII Scientific Calculator
How to insert the ink ribbon in a Canon calculator CP1213D
  • Anonymous Mar 18, 2014
    cant get rid of I display on calculator
    the ribbon will not advance when using the calculator. Tried reversing the ribbon. Tried turning the ribbons manually and they wont move. Help.
A lot of trial & error but finally figured it out. The ribbon winds around the outside guides towards the number cartridge or wheel.
Posted on Apr 15, 2009
How do you change ink ribbon/cartridge?
It's the ink roller you need to replace - it's on page 3 of the user manual (attached link to it). Canon P23 DHV User Manual Page 3
Jul 12, 2016 | Canon P23-dh V 2 Color Mini-desktop...
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How to ink new roller for shart EL1197Hii
EL-1197 Calculator Manual - you
pdfstream.manualsonline.com/.../90aef457-2ed5-4a03...
Translate this page de la calculatrice SHARP, veuillez prendre les ... Insert the new ribbon. 6. ..... AC adapters, ribbons, correction tapes, ink rollers, cables, printwheel, or paper.
Jan 24, 2016 | Office Equipment & Supplies
How or where is the ribbons located.
It does not have a ribbon, it has inked felt rollers, It clips out of the
top of the machine.
https://www.google.com/search?q=Canon+P23-DH+V&rlz=1C1VFKB_enUS661US661&oq=Canon+P23-DH+V&aqs=chrome..69i57j69i60&sourceid=chrome&es_sm=122&ie=UTF-8#q=Canon+P23-DH+V+ink
Oct 01, 2015 | Canon P23-DHV Calculator
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
Need a new ribbon where is it located and what is model number
It's not a ribbon, but a little ink roller that is under the little window by the printer digits. Mine is dry, and I need a new ink roll or a way to re-ink the old roll. Sorry I'm not much help.
Feb 21, 2010 | Canon P23-DHV Calculator
Is there a ink ribbon for my Canon P100-DHII calculator
This link shows the part numbers for the ink rollers and paper rolls.
Jan 19, 2010 | Canon P100-DHII Calculator
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Ink ribbon
It takes a CP-13 ink roller. The cheapest I could find was a 5 roll set online at the Canon store. It is $16 wth a $5.99 shipping and handling charge. They also charge sales tax. The rollers can be bought at many places including ebay. It's removed by pulling up on the right hand little tab part. The new one should snap right in. Be careful not to touch the ink section. The roller is the same for any P23-DH machine it doesn't matter what Roman numeral one you have.
Sep 05, 2008 | Canon P23-DH Calculator
Canon Calculator; P28-D
Hi there, there are a couple possibilities. First, Remove the cover where the paper feeds out, if there is a ribbon or an ink roller in there it will need replacing. This you can get a staples. The other possibility is, if there is no ribbon or ink roll, it is probably a thermal printer which means is uses a special heat sensitive paper. If this started when you changed the paper, this is most likely the problem. This you can also get at staples!
Jun 19, 2007 | Canon BP120 DH Calculator
Canon CP1213DII Scientific Calculator Logo
895 people viewed this question
old marine
old marine
