Question about OKI C5250n Printer
Oki c5250n paper jam
Oki c5250n
381 paper jam from tray 1
382 paper jam from mp tray
cleaned all rollers and looked for any objects
doesent jam all the time though
help
  • 44 Answers
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
Oki MC361 keeps jamming when paper feeds from printer tray or manual feed.
Take out both the drum tray and the transfer belt. Reseat the transfer belt and make sure both clips at the sides are locked down. Reseat the drum tray and checked it is firmly located. Re-try your prints. If it still fails, take the paper tray out and check for a paper fragment in the paper feed path.
Oct 07, 2017 | OKI Office Equipment & Supplies
381 error paper jam oki b431d
381 error indicates a jam under the drum. If no jam exists try using canned air to blow out the printer. Caution, toner dust may blow up in your face.
Jul 16, 2014 | Oki Electric Industry B431d Printer
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
We have an Oki 5200c and are printing color postcards on 110 lb card stock. The properties for the printer are set to heavy paper. We have tried using the regular drawer and almost immediately it stops...
Wrong size paper or paper setting in the software settings. Or the dreaded plastic gear/roller cam has warn down. You'll notice some parts are plastic designed to ware out.
Apr 17, 2017 | OKI C5200n Laser Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
381 Paper Jam
yep thats classic feed rollers problem... I would say... your next step is to look for the next set of feed rollers... and possibly check your sensors... also you can get all the manuals here... have fun
Nov 06, 2009 | OKI C3200n Led Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Apr 09, 2009 | OKI C5250n Printer
Printing envelopes on the Oki C5250
There are 2 entrances into the multi purpose tray. The one I needed access to opened from the sides and not the front (which opened the entire front cover). There was then a flap inside which allowed me to adjust the size of the documents to feed in, including envelopes, which the main tray doesn't.
Mar 18, 2009 | OKI C5250n Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
OKI C5250n Printer Logo
508 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
