Went from audio and video to audio only
I have a Onkyo HT-R530 Audio-Video receiver coupled with a Onkyo DV-CP702 6 disc DVD player. Everything was working, including audio and picture, until I carried two remotes together (one on top of the other) and apparently pushed some button. Now all I have is audio, and the picture is a few fuzzy B&W lines which are distorted. How can I get my picture back?
This happened a few years ago, and after a few 100 mile trips to a authorized repair shop in Lexington, KY, the problem was some kind of switch or button was either turned on or off incorrectly, as the DVD would work if connected directly to the TV. As we enjoy the surround sound of the AV receiver, as well as the component video hookup for the picture, we would really appreciate some minds sharper than mine (>99% of population) seeing if they can help, as season one of Big Bang DVD is still waiting patiently to be finished the first time.
Please help?
  • 371 Answers
Actually, I don't think your problem is a matter of buttons pushed on a couple of remotes at all. I looked around the web and noted several instances that instructors may have confused readers, including those of the notably confusing user manual, as to how many of the multiple video inputs can be used simultaneously, and I believe you should choose the highest fidelity video input, whether optical or even composite, since your symptoms seem those of a situation where several video inputs
are superimposed one upon another, which is an absolute no-no, and can ruin your video amplifier.
Check for multiple video input hookups before you burn out the vid-amp.
Posted on Apr 14, 2009
MANUAL GUIDE OWNER ONKYO RECEIVER AV HT-R530
Hi Javier, you can located the owners manual at the following link, http://www.onkyousa.com/Downloads/manuals.php?source=globalnav. Note that your unit is part of the HTIB HT-S780, Thanks, JT
Aug 24, 2015 | Onkyo Audio Players & Recorders
How to hook up a Onkyo DV-CP500 5 DVD/CD to a Onkyo AV receiver HT-R500 and a Hitchi 43FDX15BV2G005104 HDTV?
From what I find on the internet, the Receiver and the DVD player do not have any HDMI connections. Therefore, I'm using the S-Video connections. The best way to hook these components up is the following.
DVD player - Use an S-Video Cable on the OUTPUT and connect this to the S-Video Input on the Reciever. Also, connect the two audiot OUTPUTS (red/white) on the DVD player to the RECIEVER's two audio INPUTS (red/white)
RECEIVER - Use an S-Video Cable and connect to the S-VIDEO MONITOR OUTPUT and this will connect to the TV's S-VIDEO.
Speakers will connect to the Left Right Front Speaker, Left Right Rear Speakers, and Center Channel. The sub woofer needs to be connected to the Sub woofer/PreOut terminal on the Receiver.
Oct 23, 2014 | Audio Players & Recorders
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Jan 12, 2009 | Onkyo Audio Players & Recorders
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Remote controller codes
Go to Onkyo's website http://www.onkyousa.com/. rest the cursor over the support button at the top of the page. Adrop down menu will appear. Select owner's manuals. Select receivers on the new page. Select the manual for your model (HT-R530). It is a PDF file. At the bottom of the manual will be a section about the remote with the codes.
Cheers
Jan 19, 2008 | Onkyo HTR500 Receiver
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
