While running, my KitchenAid classic makes a knocking sound. It seemed to be loose at the pin that joins the motor housing to the stand. The last time I used the mixer, the pin actually came half out of its hole. The mixer was brand new and has only been in use for a couple of months (6-8 uses total).
Comments:
Sep 13, 2007
- I've never used a stand mixer before, so I wasn't sure whether they are supposed to run smoothly, or if maybe the knocking was normal.... I guess the pin having come out answers that question?!?
-   thank you very much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!-   Guest
Dec 18, 2007
-   Hi. Great solution. It worked perfectly. I had the same problem with my artisan stand mixer. While on the top would clank and the pin would gradually "walk out" of place. So, turn the mixer over. The screw is a slotted screw inside the base of the mixer. You can only see it by turning it over. At first I thought they meant the screw you see when you lift the top up. It is not. You have to turn it over and look inside the base. You'll see it there deep inside where the top and bottom join. By the way, I called and described this to KitchenAid and they said it could only be fixed by an authorized service person. Ha!!! They are 40 miles away and I use my mixer every day to bake bread. Guess if I ever want a second career, I'm qualified to be an authorized repair person now. Thank you so much!!!!-   KneadsBread
"Screws just fall out all the time, the world is an imperfect place." John Bender - The Breakfast Club.
I came across this site looking for the same answer. I tinkered with my KSM90 model and think I found the solution.
If the hinge pin is vibrating out of its slot, unplug the mixer and flip it upside down. (Removing the bowl makes it easier). You should see a screw centered over the hinge pin. Center the hinge pin and tighten the screw.
This should do it, although I tightened about every other screw on the machine before I found this one.
General rule of thumb is, with electronics, if you hear something rattling or coming loose that shouldnt be get it worked on or looked at immediately before it causes more damage.
Since yours is still under the manufacturers warranty immediately contact them to see what the steps are under the warranty.
My sister had the same issue which was beyond the warranty it was only the matter of months before it died on here. this is something that cant be fixed by yourself I'm sorry to say...
My pin came right out and I couldn't get it back in. I turned it upside down like someone recommended and loosened the screw, still couldn't get it to line up and go all the way through. I finally put a little cooking oil on the pin, turned the machine on it's side, and it went all the way through. Then I retightened the screw.
I have the same problem, but still can't get the pin to go all the way through. I tried oiling it as suggested above, but had no luck - it sill won't go any further than the hinge - I have tried from both sides. Until I get this sorted out, my expensive Kitchenaid mixer cannot be used.
My first time using pasta attachment with my kitchenaid artisan mixer. Used by directions in manual...
(More)
My first time using pasta attachment with my kitchenaid artisan mixer. Used by directions in manual for about 8 to 10 minutes. Mixer began to slow down. I turned off for 30 minutes. Now mixer will not complete one rotation and is making slight buzz. PLEASE help.
model ksm90wh will not turn on, brand new out of the box. if we play with the speed control we will...
(More)
model ksm90wh will not turn on, brand new out of the box. if we play with the speed control we will occasionally get a partial response (couple of rotations of the whisk..
I have Kitchen Aid Stand mixer Classic Model .Does not Start at all nothing happens when I move the...
(More)
I have Kitchen Aid Stand mixer Classic Model .Does not Start at all nothing happens when I move the switch to any speed. Just sits there .
Chenging speed while operating from high to low and from low to high without toching the speed...
(More)
Chenging speed while operating from high to low and from low to high without toching the speed control button.Is a 6 quarts 575 watts khitchenaid mixer.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
