Hi when I start the computer, at the beginning i get error messages like, sata drive not found press f1 to continue press f2 to reboot, but i tried both f1 & f2 still windows doesn't start goes back to same error. So please help me with this issue
  • 3,267 Answers
Open the side cabinet and check all the power connections to all drives. They heed to be snug tight in order to function, also check the cables too. Now start-up your computer and hit DEL to enter BIOS. When on the screen which shows your HDD & CD rom, check if all of them are registering in the BIOS. If not fiddle around the power cables and make sure that drive is getting power by feeling the vibration of that drive. Also check your jeyboard for any depressed keys and see the PS2 jack to check that no pins are bent. It should work after that unless your HDD has become corrupted.........sodeep
Posted on Apr 14, 2009
    Problem Solver:
  • 3 Answers
Hi...you can try to remove the battery of your motherboard..the battery is located somewhwere in the bottom of the motherboard..it will reset you bios settings to default.
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
My dell dimensions e310 is having problems.. when i power it on it says Drive 1 not found: Serial ATA, SATA-2 Strike F1 key to continue, F2 to run setup.. When i press F1 it says NTLDR is missing... I...
1 . Insert your Windows installation CD. Reboot the computer. Your computer detects the boot media in your drive and asks you to press any key to boot to the Windows installation disk. Press the space bar on your keyboard. A blue installation window is shown.
2 . Press the "R" key to start the Recovery Console process. Press the "1" key to open the command line console. You are prompted for the administrator password. Enter it into the console and press "Enter."
3 . Type the following text into the command line:
copy e:\i386\ntldr c:
4 . Replace "e" with the drive letter for your CD-ROM drive. This command copies the NTLDR file from your installation CD to your hard drive
5 . Remove the CD from the drive and reboot the computer again. The Windows operating system should successfully boot.
Thanks for using Fixya.
Feb 03, 2011 | Dell Dimension 4600 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When I turn the power on the computer beeps twice and I get a message saying that there is no secondary drive and it gives me the options of pressing f1 to start windows or f2 to go to setup.
Press F2 to go to setup. See if there is a listing of drives anywhere. It should say something like "fixed disk 0", "fixed disk 1", or "PATA drive" "SATA drive". Use the arrow keys to select the secondary drive (probably drive 1) and hit enter; change it to "none" or something similar. Then save the settings and reboot. That should take care of that message.
Jun 18, 2010 | Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Press F1 to continue and f2 to setup. How can i remove it please?
after pressing f2.....bios setup was opened.....go to drivers.....and than open diskette driver.....select off .....your problam is solve 1000%
Dec 05, 2008 | 10 10 Computer Network adapter Cable...
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Problem when i start my computer have a choice F1 and F2
just insert the xp cd and choose repair in it .......it will remove the error message
Jun 20, 2008 | 10 10 Computer Network adapter Cable...
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
