Question about Lucent Definity 8403 Corded Phone
Lucent tech phone system att 8434 phone
In a hotel setting, one room has a "do not disturb" message on their phone. How do you reset this, so that they can get calls?
SOURCE: Stop ringing at certian phones when outside calls come in.
Partner, all releases.
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Posted on Jan 13, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: program Lucent 4406D+ to call forward
Look for "Forward"
Posted on Mar 24, 2009
  • 856 Answers
SOURCE: I have a Lucent (Avaya) Partner 18 phone system.
see if the DND or do not disturb is on. It should be a lit button programmed on the set, if its not programmed press feature 00, press a blank button and press feature 01
Posted on Sep 11, 2009
  • 8 Answers
SOURCE: I need to rerecord the greeting message for my phone system.
According to the instruction manual, which can be found at:,
1. Press A.
2. Choose the announcement location by
pressing s until the appropriate
mailbox is displayed.
3. Press R. Begin speaking after the beep
4. When you are finished, press S.
You will hear your new announcement.
5. Repeat Steps 1-4 to record another
— OR —
Press S.
1. Press A.
2. Press s to choose the announcement
you want to review (A, B, C, AO,
MBOX 3, MBOX 4).
3. Press P to hear the selected
Or, if you're away from the office,
You can re-record any of the announcements
currently in use by any
line or mailbox.
1. Contact the answering system.
2. After two beeps press a number key
(1-4) to select a line or mailbox, then
press 4*. The system beeps and begins
3. Speak into the telephone in a normal tone
of voice.
4. Press # when you are finished. The
system beeps once and plays the new
To review your announcement, press a
number key (1-4) to select a line or mailbox.
Press 41 after the two beeps to play
your announcement.
NOTE: If announcement is being used by
both lines, re-recording the announcement
will change the announcement heard on
both lines.
Hope this helps!
Posted on Oct 03, 2009
SOURCE: Lost my password for the voice mail on lucent
Access Programming Main Menu:
Press <Intercom> 777
Press 99#
Enter main system password and press #
Press 9
The system plays the programming options.
Press 4 to program mailboxes
Enter the mailbox number and then #
The system plays a list of options, choose option 3.
This will reset the password to 1234 for that mailbox
hang up.
Posted on Aug 09, 2010
  • 2460 Answers
SOURCE: Do you have a programming
You can do this in single digits if you change the selector code to 6. Look at page 6 of the following pdf.
Each selector code, except 9 is preceded with a 5, which is direct extension transfer. If you create a digit, say 7, selector code of 6 and put your extension range in the extensions, you should be able to dial 71x and do an immediate transfer to voice mail. This is sort of a guess as I don't have my Partner system set up on the bench.
If you strip the right portion of the url away, you can find a full VS r5 manual on the wedophones website.
Posted on Feb 23, 2011
0 characters
1 Points
Lucent partner 34D calls go directly to voicemail
Sounds like either you have do-not-disturb activated, or you have call-forward-all to voice mail set. You should have call-forward-no-answer turned on but it's easy to enter wrong code. Find a list of codes for your system and see if its one of those.
Apr 19, 2014 | Lucent Phones
ATT 1825 message light flashing messages will not play
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 18, 2014 | Lucent AT&T 1825 Corded Phone (23069)
I have a Merline phone system. I would like to hook up a reular AT&T phone. How can I accomplish this?
What do you mean a regular AT&T Phone.
The only phone phones that are compatible are the HFAI sets, BIS sets and some cordless phones.
What model do you have?
Mar 24, 2011 | AT&T ATT / Avaya / Lucent Merlin 820...
Program "Do not disturb" on business phone
From the manual: You need to program a button with FEATURE 01.
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Mar 16, 2010 | Phones
How do I reset the passord for my voice message system?
intercom 777 *, *, 0, #, 12345678, # press 9 to admin, listen for mailbox administration, press appropriate number, then listen press, listen but it should be mailbox number thn 6 to reset !!!!! it deletes all messages. then reapeat for all extensions. listen to prompts after reset they should be all set to 12345678 #
Sep 15, 2009 | Lucent PARTNER18 Corded Phone
I have a Lucent (Avaya) Partner 18 phone system. One extension will not ring when there is an incoming call. I have set the extension to immediate ring but it still does not work. Any other ideas to try?
Sep 11, 2009 | Lucent PARTNER18 Corded Phone
We need to reset the voice mail password that an ex-employee had set up
I cannot access the voice mail messages on my lucent phone, a past employee had the password, and I cannot access it. How do I reset the password?
Jun 23, 2009 | Lucent PARTNER18 Corded Phone
Lucent mlx-10dp
Are you trying to give specific extensions to specific people , if so then that is done by moving the jumper wires on the phone system and should be done by a tech .
Feb 16, 2009 | Lucent PARTNER18 Corded Phone
Reset pasword lucent partner 18d
You will have to call in a pro. We can not put the master passwords on the open internet.
Dec 30, 2008 | Avaya Lucent Partner 616 Phone
Lucent 7720 will not stop beeping or reset message counter
have you tried removing the battery and letting it sit unplugged for 10 minutes
Sep 12, 2008 | Lucent Phones
Lucent Definity 8403 Corded Phone Logo
61 people viewed this question
Top Lucent Phones Experts
Are you a Lucent Phone Expert? Answer questions, earn points and help others
