IC-VCT 49X3F PZ F1000
MALFUNCTION "IC"VCT49X3FPZ F 1000
THANK YOU;ALL IS DONE.
Posted on Apr 16, 2009
  • sahilshah Mar 30, 2011
    magaj ni ma chodai gai 6e ic detail search karwama ne karwama .....! tamari ma no bhosdo mare bhadwao chode akha google ma kyay nathi su gand ma nakhine betha 6o.....?
Onida oxigen thunder crt tv picture fold in verticle bar..ic used vct 49x3f pz f1
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 27, 2015 | Televison & Video
Vct49x3f pz f1000
I could tell you one hundred solution, but would it help if none of them were correct?
What good is a solution, if you don't know what to do with it?
Sometimes, some skills are needed to repair things.
Feb 18, 2014 | Panasonic Cameras
P0012
P0012 - "A" Camshaft Position - Timing Over-******** (Bank 1)
OBD-II DTC Trouble Code Description
What does that mean?
A code P0012 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms
Most likely a P0012 DTC will result in one of the following:
hard starting
poor idle and/or
stalling
There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes
A P0012 DTC trouble code may be caused by one or more of the following:
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed timing valve control solenoid (stuck open)
Possible Solutions
The main thing to check is to verify the operation of the VCT solenoid. You're looking for a sticking or stuck VCt solenoid valve caused by contamination. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
Nov 26, 2011 | 2004 Ford F150
I've got a 1994 honda F1000 which I just purchased.......when driving slow in traffic it heats up and then shuts off......what would cause this?
Is it getting too hot and tripping something?
Does it start again when it cools down?
Is the fan starting up when it gets warm?
Sorry this isn't really a solution, just a thought as to what could be the problem.
Good luck
Jun 26, 2011 | 1994 Honda CB 1000 Big 1
EL VEHICULO TIENE PERDIDA DE POTENCIA Y EN EL SCANNER MUESTRA LOS CODIGO PO0011; PO0012
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
A code P0011 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0011 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms: Most likely a P0011 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes: A P0011 DTC trouble code may be caused by one or more of the following:
Possible Solutions: This DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
P0012 - "A" Camshaft Position - Timing Over-Retarded (Bank 1)
A code P0012 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-retarded, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms: Most likely a P0012 DTC will result in one of the following:
hard starting
poor idle and/or
stalling
Causes: A P0012 DTC trouble code may be caused by one or more of the following:
Possible Solutions:
Hope this helps. Suerte.
May 30, 2011 | Toyota Yaris Cars & Trucks
Do you have to remove the fairing on a honda cbr f1000 to put in anti freeze?
No it is under the right handlebar under that little piece of plastic with the screw in it.
Feb 26, 2011 | 1993 Honda CBR 1000 F
2006 chevy HHR 2.4L code P0011 ??
Potential Symptoms
Causes
  • Incorrect camshaft timing
  • Wiring problems (harness/wiring) in intake timing control valve control solenoid system
  • Continuous oil flow to VCT piston chamber
  • Failed timing valve control solenoid (stuck open)
Possible Solutions
Sep 25, 2010 | 2006 Chevrolet HHR
Codes p0340 p1380 come on every time i start the car
P340 is camshaft position sensor malfunction. P1380 ic VCT Solenoid Valve short or open. Most likely camshaft sensor needs to be replaced. The vapor canistor solenoid is also most likely burned or rotted out.
Sep 01, 2010 | Ford Escort Cars & Trucks
0nida tv why to any tuch rimort boton so of mument
English language without abbreviations would help you get an answer.
May 28, 2017 | Bushnell ONIX 200 GPS Receiver
Televison & Video Logo
917 people viewed this question
Top Televison & Video Experts
Electro Med Services...
