Question about Gateway CX2610 Notebook
I need to replace te swivel/hinge on the cx2610.
I cannot see to disconnect the cables to thread them thru the swivel... I have the swivel/hinge exposed and loose...from another post here.
Lenova x230 tablet swivel hinge repair
It is possible to replace the hinge, but it is a couple hours of tricky work. If you are not comfortable completely dismantling your computer, I would take it to a repair shop. You can usually find the hinge on ebay. Just search for "thinkpad x230 tablet swivel hinge part".
I replaced the hinge on my x61 tablet without any trouble, but I am very comfortable with repairing computers. Take lots of pictures to make sure you get it back together correctly, and keep track of where the screws go, there are a lot of them. Good luck!
Here is the repair manual for the x230:
https://download.lenovo.com/pccbbs/mobiles_pdf/x230t_x230it_hmm_en_0b48730_02.pdf
Jul 10, 2014 | Lenovo ThinkPad X61 Tablet PC
Easynote te 11 broken hinge
Check out these WEB sites for assistance.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Oct 02, 2012 | Computers & Internet
Why does my screen only turn on when I swivel it
This can be caused by a faulty microswitch inside of the hinge assy or a bad lcd cable. The lcd cable goes from your lcd to the main board. This would need to be repaired by an experienced technician.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Samsung Video Cameras
Bottom hinge on GE side by side broke. Need to replace hinge but water line for ice maker/water dispenser runs thru it. How do you remove the water line so you can take off the door and replace hinge?
there should be a disconnect behind the kickplate under the door,also a disconnect for the wire harness too.don't cut anything,i've found people cut the wires and then had to replace the door for this.if for some reason there isn't a disconnect there remove the hose from the water valve but there's a disconnect there.pop off the kickplate and you should see it
Jan 22, 2011 | GE Refrigerators
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
I need to replace the battery. How do I do this?
Hi!!
The battery is located in the fender, ahead of the right front tire. Te battery can be removed without reovint the tire, but removing it improves access.
Here is how to remove/replace the battery
Disconnect battery cables, negative first, then positive from remote terminals.
Remove air filter housing
Remove the two battery hold down clamp bolts and clamp.
Loosen right front tire lug nuts, rise the vehicle, support it w/jackstand and remove wheel.
Remove battery cover/splash shield from wheel well
Slide battery toward rear of vehicle and disconnect battery cables.
Remove old battery thru wheel opening and insert new one.
If helpful, click below
Apr 13, 2010 | 2003 Chrysler Concorde
Bad starter on 94 pathfinder how can i start to get to mecs?
If you have a standard shift transmission.....give it a push with the key on and release the clutch in 2nd gear to start it.
An automatic will have to be towed.
Sep 06, 2009 | 2005 Nissan Sentra
Gateway CX2620 Swivel Screen Laptop
This is the worst solution I've ever heard. This guy is trying to steer you wrong I'm pretty sure. There is zero point in removing all the screws from under the batter/ zero point to removing the area around the power button. Absolute BS. The only part to remove is the part just above the top of the keyboard (silver strip with some black). Then by removing that you can pry the swivel black plastic cover off. Whatever you do.. do not follow Scott's writeup here. I'm telling you. It's sad it's stayed up so long.. so had to warn.
Dec 10, 2008 | Gateway Convertible CX2620 Notebook
My Gateway notebook CX2610 needs a new hinge.
bring it to your closest repair shop,but make a few phone calls first to see can they fix it. then evaluate the cost of repair compared to a complette replacement laptop and use the damaged one a a workstation (check your home insurance if the hinge was broken through accidental damage)
Aug 28, 2008 | Computers & Internet
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Gateway CX2610 Notebook Logo
156 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
