Question about RCA E13320 13" TV
Flyback transformer on television
My wife could hear cracking comming out of the tv,but ignored it untill it got too bad and eventually unplugged it. i pulled the back off and tried it again,the flyback transformer had a hole burned in the casing and was arcing to the top of the transformer,so bieng mr fixit i got some glue and filled the hole,now the arcing has stopped but when i turned it back on the screen has only a single white line across it.i have located a flyback transformer,but now im wondering if a new flyback transformer will fix it ,or if this has damaged something else. i dont know too much about this stuff and would greatly appreciate any help.thanks
  • twelvetreeez Nov 23, 2007
    I too have a single white line across the screen. I have heard a little static in the background, almost as if the reception was a little off. Left for work at 7pm, and it was working fine. Came home at 7am, thin white line acroos the screen. What and how much? Thankyou
  • 30 Answers
I beleive something in the vertical circuit got damaged. Check resisters to see if they are burned and locate the vertical IC has about 8 to 10 pins. It stands up on the board and all the pins connect into the board in a straight line. If you can't do this, take the set in for service. Get the fly back replaced and the vertical section fixed.
Posted on Aug 03, 2008
Does anyone know here the flyback number of sanyo tv model DS25390, chassis#: 25390-02...tnx!
Posted on Feb 17, 2008
    Genius:
  • 1,153 Answers
Single white line across screen mean a vertical colapse. So you will need the vertical output and maybe a cap around [email protected]
Posted on Sep 13, 2007
SOURCE:
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
Mpy TV makes a popping noise for about 30-45 seconds when you first turn it on, then stops. Is this a bad horizontal output transistor?
If this is a CRT type TV, then I would check for cracks in the flyback transformer. In a darkened setting, you should actually be able to see the sparks jumping to the frame from the transformer.
Replacement of the transformer is the ultimate solution, but you may be able to seal the crack with silicone sealant (like the kind used for fish tanks) until you can find a replacement.
If you can't see the sparks, it could be sparking internally, and simply must be replaced.
Jul 31, 2011 | Televison & Video
I have a Phillips Rear Projection TV and when it is turned on, it has a hiss coming from the back. Is this dangerous? Is there a way to fix it?
The flyback transformer is most likley arcing. It is high voltage so eventually the set will shut down and not power up again untill the transformer is replaced. However those flybacks for that model are very hard to find.
Sep 29, 2010 | Philips Magnavox 55P9271 55" Rear...
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
TV is beeping from the back.
The horizontal output transistor is shorted and probably the flyback transformer is bad as well. Expensive to fix.
Mar 28, 2009 | RCA P52926 52" Rear Projection Television
My tv won't turn on.
You probably have bad connections on the flyback transformer. With the back off of the set, on the left side, you wlii see a transformer with a big red wire coming out of it, The connections under that transformer are bad. Be sure the set is unplugged when doing this!
Nov 29, 2008 | RCA HD56W66 56" HDTV
Tv wont come on
Most times when you hear this kind of sound on a TV it is because the flyback transformer is bad (from what I can remember anyway!). Its been a while since I repaired TV's, so hopefully someone can verify my info. The flyback transformer steps up the voltage very high which powers the color tubes. If that is bad, you will get the thunk sound. Also, if memory serves me well, there is a high power output chip that could be bad as well. Please, anyone who knows TV's, please verify for me. It has been years for me!
Apr 13, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA F36685 wont power on
Probable bad flyback transformer....verify service number
last three digits YX2....Part # is 244247.............................T.
Nov 28, 2007 | RCA F36685 36" TV
Rca f27442
Check for shorted base-collector junction on horizontal output transistor designator Q14401. Also coil L14401 going to base of transistor needs to be desoldered, scrape ends, resoldered. If horizontal transistor is shorted, real possible flyback transformer bad.
Dec 16, 2006 | RCA F27442 27" TV
RCA E13320 13" TV Logo
392 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
