Question about Xerox Phaser 7400/DXF Laser Printer
Error 188 on xerox phaser 7400
Error 188 on phaser 7400 what is it?
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • 2072 Answers
SOURCE: I have a Xerox Phaser
That is a motor driver board fault.
May be that board itself, Could be a waste bottle interlock not being made.Possibly the engine control board.
Posted on Apr 23, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Posted on Dec 17, 2009
SOURCE: xerox phaser 7400 replaced yellow toner, but still
open and close cover after replace chip cartrige
Posted on May 19, 2010
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Getting error code 929 on a xerox phaser 7400
Check the Xerox.com website and follow the links for assistance.
Good luck.
Apr 16, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox 7400 error 917
From Google: Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
May 25, 2009 | Xerox Phaser 7400/DT Laser Printer
I have a Xerox Phaser 7400 DN and it is reporting a Fault 188.
Apr 23, 2008 | Office Equipment & Supplies
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
758 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
