When recording a channel and yo uchange to another "no signal" message appears on all other channels
When watching a channel and you decide to record it, if you change channel "no signal" message appears. It doesn't record two channels at any time
  • Anonymous Mar 25, 2014
    I switch on TOPPRO and erro message above is appeared
One of the two leads going into the sky + box was loose.
Posted on Apr 15, 2009
How to set up VCR to record and watch show at the same time
Put the TV on to the channel you use to watch recordings. Put in a blank cassette. Put the VCR on to the channel or AV input that picks up the signal from your source. Press the record button and watch the channel at the same time.
Sep 08, 2014 | RCA Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
LG RH399H
I have the same problem with the same model LG, bought a year ago. It only gives the 'Record-blocking signals detected' message when there's something I really want to record. Over the winter it was Jane Austin's Pride and Prejudice. Today it is the British Open Golf from Turnberry. We are out tomorrow, for the last day of play and can't record!!!!! It seems this player has build in blocking signals even to channels we can normally watch. Any help would be appreciated - before tomorrow, July 19th.
Jun 21, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Dvd recorder hard drive DVDR5350H
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
Oct 03, 2008 | Televison & Video
DVD records a black screen if tv is on standby.
You have tuned the dvd recorders channels? dont forget a recorder dvd/hd/vcr is actually a tv set without its own screen and to record from channels you need to have its on board channels tuned in... what you have been probably doing is using a function on many recorders that records direct tv... what this means is it records the feed back signal through the scart lead of what ever channel your tv is tuned to at the time that is why no tv on = no signal
Sep 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
