Question about Brother Office Equipment & Supplies
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button possible. Please help,
  • barbs22 Apr 14, 2009
    I am not sure about how to unplug printer. I lifted the top of printer and pulled out that plug.
    and I don't know how to reboot.
    I unplugged the printer by lifting top and pulling that one.
    I don't know how to boot.
  • 3,267 Answers
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Posted on Apr 14, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Apr 14, 2009
    OK disconnecting the power supply to the printer will shut it. The PC give the normal shut-down order and after it has shut down, restart as one normally does. After that try to follow my earlier suggestions and see if it works now................sodeep
  • Sudeep Chatterjee
    Sudeep Chatterjee Apr 28, 2009
    Just switch off the power supply to the printer. On your PC open the print queue and cancell printing of the remaining pages. Wait till you dont see any documents queued up for printing. If it does not get cancelled restart your PC, This time it should be gone. Power your printer from the main switch of the printer(on/off) Now if you want to print open that document, print it in batches of 5 pages at a time to reduce the buffer load. Or print all odd pages, reverse the paper in the stack and print the even pages, again in batches 0f 5-7 pages at a time. I hope this helps............................sodeep
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Reverse printing
Right click 7105>Properties>Printing Preferences>Finishing>Collate and Staple. This should be able to be changed here.
Jul 16, 2010 | Canon imageRUNNER 5000 Copier
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Oct 04, 2009 | Canon MX300 Office All-In-One Printer
Canon C5185 networked printer. Printed a 437
you are filling up you memory, inless you want to buy more memory, you have to do it in steps.
if you reduce the output quality to draft, you can get more pages per set.
Aug 11, 2009 | Office Equipment & Supplies
Only one page is printing out of many pages
On your print preview, or print settings from your document or page, Make sure the settings say print all or print page 9 or 9 or whatever you are using
Aug 06, 2009 | Lexmark P4350 All-In-One InkJet Printer
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Feb 03, 2009 | Kodak ESP 5 Printer
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
297 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
