Washing machine wil not fill - tries several times then stops and all lights except 4 go out
Fisher-Paykel Samrtdrive 7.5 when starting machine - water starts filling - then stops, then starts filling again then stops every 10 to 15 secs after few seconds then starts again - repeats this several times then all lights go - including temp, cycle type etc except for 4 lights on top row which indicates wash phase. The 4 lights on are - two green wash lights - not together though ie separated by one green wash light which is out - Also red spin light is on and orange light next to red rinse also stays on. Reading left to right from Spin light we have - red Spin on, orange next to it on, Orange rinse off, green wash on, next green wash off then next green on, then every other light on entire panel off.
    Problem Solver:
  • 10 Answers
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Posted on Dec 27, 2010
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
505 people viewed this question
Top Washing Machines Experts
