Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
How does a external USB SATA drive dock
My fantom titanium 500g external drive recently stopped working .(the drive wont spin) ... can i take the drive out of it and put it in one of these new external USB SATA drive docks? http://www.vantecusa.com/front/product/view_detail/295
thanks!
The Solution: ... IT WORKS REALLY ...
Point 1: Remove power from the mains.
Item 2: The device from your PC, remove the USB plug.
Point 3: The USB Titanium External Hard Disc Enclosure Open, just the screws of the housing, with a special wrench to open.
The drive from the connector of the USB connector for one minute to remove, then the hard drive with the connector of the USB connection,
connect together.
Point 3: The hard disk into the housing insert all the screws screw.
PLEASE precisely again check that all connections are properly connected.
Power to the drive plug the USB connector from the HDD to the PC or notebook is already running and the hard drive, as before, during initial installation of the device.
So everything supper dooper easy ...
Posted on Jun 27, 2009
  • 432 Answers
Yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Posted on Apr 14, 2009
Clicking noise, won't mount
the controller on the external drive could have gone bad. i would first try removing the hard drive from that external enclosure and use a usb or esata dock and see if itll mount.
Nov 26, 2013 | Fantom Titanium Hard Drive
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
I have a Fantom Titanium II FireWire+USB 500 GB Hard Drive that needs a new casing (blue light / red light / drive not spinning). I do not know if the current drive is IDE or SATA or something else. I...
Yes it does make a large difference. I did a search on that drive and there a lot of people who had good luck getting a replacement from the manufacturer. As far as a case is concerned I recently purchased one off of amazon and it was very inexpensive. Just look up "drive enclosure" on amazon.
May 02, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other...
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Dec 30, 2010 | Fantom Titanium Hard Drive
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
Data recovery from External HD
Matthew,
First thing you should do is remove the drive from enclosure and connect it direcly to the PC or via another USB enclosure.
If it still doesn't power up then most likely the PCB is dead. You can try to find another drive of the same model and swap the PCBs. But as far as I know often this doesn't work.
Here's some info about burnt PCB (in the beginning): http://datacent.com/datarecovery/hdd/western_digital/
Take care.
Nov 03, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
423 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
