Question about Sony KP-53HS10 TV
No picture hi i have a sony kp-43ht20 rear projection tv. when i turn it on it makes a clicking noise but nothing comes on. a lil red light under the tv stays on. but the television itself never comes on. i let the tv warm up but still no picture shows up. i just need some help on what to do to fix it. thanks for your time rocky
    President:
  • 4,402 Answers
Does the red light give you a blinking code pause then code?
Posted on Jan 23, 2008
SOURCE:
Hi I have a sony kp-53HS10 TV. When i turn it on it use to make a clicking noise and than the tv would turn on, but now the clicking noise is gone and nothing comes on. A red light under the tv stays on....
Sounds like a Power Board / Video Board issue - stand by power is still ok - and why you have a red light - but the set is unable to power up the panel to drive a picture. Or the video board is the issue an is no longer processing the image to your panel. Based on the clicking noise - I lean towards the power board as the issue.
Dec 21, 2017 | Sony KP-53HS10 TV
What kind of bulb do i need for this model of tv
sorry but this tv is a rear projection tv , dont use buld , use 3 picture tube which are blue ,green ,and red
Apr 19, 2010 | Sony KP-43HT20 43" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
The tv doesnot turn on
either the lamp needs to be replace which eventually happen in all rear projection tvs. Do you have colored lights, flashing lights on tv? It is also very possible that the power supply may need to be replaced. If you have colored or flashing lights, please let me know which ones they are and if they are a solid light or flashing and how many times it flashes.
If the tv has sound no picture, than it is your lamp. If you have nothing what so ever, than your power supply may have to be replaced.
Mar 30, 2009 | Sony KP-46WT520 46" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-53HS10 TV Logo
219 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
