FixYa.com
Tags:
Motorola WA840G 802.11g/b  Wireless Access Point
WA840G firmware went bad :(
posted by palantbon on Sep 13, 2007
I tried to upload the latest firmware to WA840G 6.14 and it crashe din the middle up the upgrade...Is there anyway of reprogramming the flash other than using the gui..
Palantbon
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 13, 2007
Thanks for Trying (70)
Benimur
Rank:Guru Guru
Rating: 86%, 1974 votes
Based on your post/description, I would assume that though you did not complete the upgrade, you were able to restore the WA840G to the original/old firmware. Second, you still wish to upgrade again but using a different method other than web configuration.
Perhaps you can try a telnet session to 192.168.1.1 or the default which is 192.168.40.1 or the IP add you have set it to if you have modified it before. I have successfully tried this on a LinkSys WRT54G & NetGear MR814V2. Might or might not work for you. "?" or help should give you the basic line commands.
But then again, if the system has crashed and the unit is bricked, that is a harder problem and you might be better off replacing the unit.
Hope this be of some idea/help. Post back how things are or should you need further information.
Good luck and kind regards.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Wireless Access Points problems?
web pass
i do not know what my pass is i... Answer This...
Radius Server Work Around
Hello, we currently have a... Answer This...
How do I connect 3 wireless...
I have 3 wireless routers... Answer This...
Motorola WA840G 802.11g/b (49832000100)...
I want to use my WAP to share...
However, the my cable modem... Answer This...
The 840 keeps assigning a...
I have a Dlink DFI 655 router... Answer This...
Repair Service
Find Wireless Acc. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
