What could be the subtitutes of FET Transistors 2SJ26A and 2SK76A for Yamaha B 2 power amplifier
FET Transistors 2SJ26A and 2SK76A are needed for Yamaha B 2 power amplifier.. Pls contact : halilebus@ttmail.com
5 Suggested Answers
tantong
  • 138 Answers
SOURCE: Dell E173FP 17" LCD goes black after 2 or 3 seconds
Did you check CCFL lamps inside yet? If not, you should do that as well.
Posted on Mar 26, 2008
  • 286 Answers
You have to measure these parts with a multimeter to decide if they need to be replaced or not.
You have to measure for shorts. Replace the components that measure shorted.
It is unlikely you will need to replace the transformers. Resoldering them wouldn't hurt though.
And, I can't stress this enough, check all the capacitors first. 90% of the time, the faults are caused by bad capacitors.
As for where to get them, you will have to call around town to all the electronics parts supply stores and see if any of them can supply the transistors or a substitute. If not, you will have to find them on the internet and order them on-line.
Posted on Mar 27, 2008
SOURCE: Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS smas5305@yahoo.com thank you Thomas Anderson
Posted on Mar 23, 2010
  • 52 Answers
SOURCE: Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Posted on Sep 01, 2010
Additional detail about my AUREX STEREO AMP MODEL SB 130. I have change the rexridiwe / power diode but to no avail. This same result. The fuse rated 3.15 blown up 2 times. I wonder will is the cul
A module or an amp is doing a short cicuit. It's time to check if all transistors are valid. Be careful, bipolar and FET transistors behave differently. It can help to compare one by one each transistor from the RIGHT and LEFT amps. Good luck.
Mar 07, 2014 | Audio Players & Recorders
3055 transistor short
How do you know it is shorted. What is the full part number, that number is on transistors, MOSFETS and a few other things.
Jan 04, 2014 | Crown CE1000 2-Channel Amplifier
How many fet tranistors are in this unit and what is its max amp draw.?
There are 5 transistors in that unit that you are asking about. The amperage draw is about 50 amps
May 23, 2013 | Palomar Redman Cb Stop LD 450-fet LD Low...
My yamaha P7000 always lights its protection lamp whenever turn on...
The amp will require service. One or more power transistors have failed and the protect circuit keeps the power supply from blowing your speakers
Oct 12, 2010 | Yamaha P-7000 2-Channel Amplifier
What is the power output in a power amp and is it expensive
the output transistors are 5 to 10 bucks each for most.there are 2 or 4 on each channel,depending on brand .some high end amps have 10 transistors on each channel.mosfets are a different story as they run 20 to 50 bucks each and there is 2 or 4 on each channel.some amps use a big IC instead of transistors.those have 16 to 24 pins and are easy to change. Those IC are 25 to 75 for a stereo one like stk4141 etc.since most yamaha amps are dc coupled,when the output transistors go,they take out the driver transistors as well.If you replace the outputs and the drive transistors are shorted,they will blow the outputs again.
Apr 14, 2010 | Yamaha P3500S Amplifier
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
Subtitute parts for kenwood trait N3KO,kenwood trait P3KY
There are no direct substitutes. These are combination transistors made specifically for kenwood. These parts should still be available. Is there a specific problem you are trying to address?
Dan
Sep 13, 2009 | Kenwood Audio Players & Recorders
Sep 09, 2009 | Yamaha RX-V530 Receiver
Trying to find the right FET to replace burnt up ones with
hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
May 23, 2009 | MTX Thunder 5-Channel Amplifier 895 Car...
TRANSISTORS
Find a music store that sells yamaha keys and PA gear. Ask them for help. Couldnt cost more than $10 for a good schematic
Jan 10, 2009 | Audio Players & Recorders
184 people viewed this question
 Grubhead
Grubhead
