Question about Polycom SoundPoint
Couldn't contact DHCP displays on polycom phone
  • Cory Dzbinski
    Cory Dzbinski May 11, 2010
    What is the exact error? Is it "Couldn't contact DHCP server"? The exact wording is important because there are a couple different DHCP error messages.
3 Suggested Answers
corydzbinski
  • 7 Answers
SOURCE: failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Posted on Jun 04, 2009
Testimonial: "thank you"
CoquiBiz
  • 103 Answers
SOURCE: "Couldn't contact DHCP" error
Check on the router if you are distributing enough IP addresses.
Posted on Jul 30, 2009
Upgrade failed
The easiest way to fix this is to have use TFTPD32 and set the firmware in the default directory so that when the phone boots it gets its DHCP with Option 66 from the machine running TFTPD32 and automatically pulls the firmware
Jan 19, 2014 | Polycom Lands Phones
Purchased refurbished phones and they do not have the Factory Defaulted Admin Password. How to reset the Polycom Soundpoint IP501 to Factory Default Admin Password?!?
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Apr 01, 2011 | Polycom SoundPoint IP 501 IP Phone
What does this message mean: Url call is disabled
This means that your phone will not dial a url number, i.e. sip://123456789@somedomain.com. This is generally a network or configuration error, and I would specifically make sure the phone either has static DNS entries entered or is receiving DNS entries via DHCP.
Mar 01, 2011 | Polycom SoundPoint 650 IP Phone - LCD -...
Display screen reads dhcp bad conflict
There is a dhcp error. Reboot the phone.
When It says, DHCP * to program, press the STAR button.
when the IP address is displayed, change it by press 0.0.0.0. Where the dots are would be the star button. then press the #(pound) button until you see save new values, press star for yes.
Hopefully that will force it to grab another IP from teh DHCP server.
If not contact your admin.
Jan 12, 2011 | Avaya 5610 IP Phone
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
Dec 05, 2009 | Polycom SoundPoint IP 501 IP Phone
Jul 30, 2009 | Polycom SoundPoint
Apr 10, 2009 | Polycom SoundPoint IP 501 IP Phone
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom SoundPoint Logo
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
