Question about Toshiba 27A34 27" TV
Toshiba 27" standard def. TV
I'm wondering what the white narrow lines mean at the top of the screen. They seem to be going deeper down the screen by the day.
  • judy548 Sep 14, 2007
    Still don't know what to do about it. I was told the picture tube was dying. Is it worth fixing, or should I plan on buying another set?
    tHAT IS GREAT NEWS!!!!!
    THANK YOU SO MUCH!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
White narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Posted on Sep 13, 2007
  • manahar modern Sep 14, 2007
    was told the picture tube was dying?
    no in this problem it not possible .your picture tube is 100% ok
    call skilled tech to check vertical section
    it is simple problem
I had a narrow white line appearing at the top of the screen for some time, then just recently the set lost all vertical scan and left a white line at the centre of the screen. What should I look for and...
There should be any loose solder terminals at the vertical sweep output section circuit. Check all the solder terminals. Re-solder all the suspected solder terminals.
Aug 15, 2013 | Orion STV2763 27" TV
Sansui 27 standard Def.White Lines
This fault is calle technically as 'retrace lines'. It is with an adjustment fault. Visit this site to get more details and repair help to this fault. Detailed description are given there. "Electro-help" is the site name. Search for it either by Yahoo or google. It is an electronic entertainement equipments service help site.
May 09, 2012 | Sansui 27" TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
WHITE LINES
Replaced C407 100uf/35V Vertical section.
Mar 03, 2008 | Toshiba 27A33 27" TV
Poor picture quality
You need to consider the following tips herein as follow:
1) Field collapse (horizontal white line on screen)
R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
2) Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Please let me know any update
Nov 29, 2007 | Toshiba 27AF42 27" TV
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Toshiba 27A34 27" TV Logo
403 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
