Question about Dryers
Dryer runs as usual but won't heat up.
My whirlpool electric dryer model #LER7646EQ2 turns on and will run thru a drying cycle, but won't heat up. seems like everything else is working correctly, just no heat to dry the clothes. What are all the options to fix this problem?
  • seibert77 Apr 15, 2009
    Electric. I looked at the heating element and the coils are intact. All wires look fine, no breaks or disconnects anywhere.
  • Jeff Adkisson
    Jeff Adkisson May 11, 2010
    gas or electric??
  • 490 Answers
You need to check continuity across the heating element with an ohm meter looks can be deceiving
Posted on Apr 15, 2009
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Whirlpool supreme LER7646EQ2 won't heat up
The heating element is no good. They break after years of use as they heat up and cool down over and over, they wear out. The part is cheap and yes it is easy to replace. Turn your dryer around, and take off the screws to a short piece of metal that has "vents" in it. It should be sticking out a bit compared to the rest of the dryer back. normally 2 or 4 screws holding it there. You'll see the element. Just pull it out, take it to the appliance shop or Sears and get another element. Go home, stick it back in there and reconnect the panel you took off. Cheap part, simple fix...you'll be surprised how well it heats after that.
Jun 09, 2012 | Whirlpool LER5636P Electric Dryer
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
I have a whirlpool dryer, model # LER7646EQ2 drum turns, blower works, but no heat. Pulled out heating element, no coils broken or grounding out, however part of heat sheild is blackened. Before it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Whirlpool Dryers
The sensor doesn't seem to work?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 22, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer stopped running mid-cycle. I've checked drum belt; it's okay. I've checked electrical connections; they're okay. I haven't checked any fuses--don't know where they are. What's wrong?? MODEL:...
THIS STILL SOUNDS LIKE AN ELECTRICAL PROBLEM TO ME, MAKE SURE YOU HAVE 220 VOLTS FROM DRYER RECEPTACLE, 110 ON EACH SIDE OF RECEPTACLE, IF YOU DO NOT RESET THE BREAKER FOR THE DRYER, IT JUST DOESNT SOUND RIGHT STOPPING LIKE THAT WITH NO OTHER PROBLEMS,CHECK THIS LET ME KNOW THKS LARRY
Apr 25, 2010 | Whirlpool Dryers
Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Feb 21, 2010 | Whirlpool Dryers
Whirlpool DWJR - ELE, Model LER7646EQ2, about 12 yrs old.
belt may be broke since you hear the motor running.
Sep 22, 2009 | Dryers
Dryers Logo
341 people viewed this question
Top Dryers Experts
